Question about JVC Audio Players & Recorders
I have a JVC sound bar TH-BY870, ther is only sound on the subwoofer but not on the speakers. How can I check it.
SOURCE:
CLUEPATEL
  • 138 Answers
SOURCE: JVC THM303 - No Sound
Its your wire connection problem. Plz check that all the wires are connected to specific location. If wiares are ok then it might be internal circuit error! that should be repaired at authorised service stations.
Posted on Dec 08, 2007
s4u311
  • 813 Answers
SOURCE: JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
Posted on Feb 19, 2008
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
  • 16 Answers
SOURCE: JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Posted on Apr 16, 2008
tech48
  • 624 Answers
SOURCE: JVC TH-M505 No Sound
It is possible that a fuse has blown in the sub-woofer box. This unit has the entire amplifier built right into the sub-woofer. It also has a number of fuses in it. I have found that over the years fixing these units that if a fuse is blown you will also have more serious problems in the amp circuit. That is usually why the fuse will blow. They sometimes even have a problem in the main head unit with a digital transistor that is a surface mounted transistor that will cause this problem also. This transistor is part of the turn on circuit that signals the sub-woofer to turn on when the head unit is turned on. None of these problems are an easy fix I am sorry to say.
If you have at least a little experience with electronics and the right tools, like a multimeter and soldering equipment, I may be able to help you figure out the problem. But be aware that these are not easy to fix, and you may spend lots of time trying to figure it out just to find out that you will still need to take it in to a service center and in many cases when somebody tries to fix these type of units and have no experience with them they often cause more problems than they have started with.
For starters you can at least check the fuses, but please be sure to unplug the entire unit from the wall outlet before doing anything, there is a big risk of electrical shock.
The bottom of the sub-woofer has 6 screws in it (If I remember right) and those 6 screws must come out, they are rather big and you must use a number 2 phillips head screwdriver. Then after that you must take out all the screws from around the edges of the black metal panel where the speakers plug in to. When those are all out you can pull the amplifier unit right out of the sub-woofer box. Be careful when you pull it out, you will need to unplug a set of wires to get it all the way out, maybe two sets of wires, I am going off of just my memory right now, but if you need more help I will look up the service manual to help you more.
You will find at least one fuse right near the board where the A/C plug goes to and then you will find a few more fuses on the board that is on the right side while looking at the amp block from the same position you pull it out from and this board is plugged into the bottom board and is vertical but the short side is up and down, the long side is going towards the back of the amp and it is running along the metal chassis on that right side.
I hope this helps you, if you need more help just post your questions here.
Dave
Posted on Nov 26, 2008
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
Where do i find a connector cord for my powered subwoofer model no. sp-pwm606
There are a few on eBay. Search for "JVC THM505 cable" and check the 'include description box'.
If you need the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
Mar 16, 2011 | JVC SP-PW100 Subwoofer
Jvc th-m303 sub woofer not working all other speakers are fine
check your internal wires inside subwoofer.b4 that try to connect to other instrument to make sure it not working.
May 12, 2009 | JVC TH-M303 System
The subwoofer lites but no sound
Have you gone into the menu settings and adjusted the sub woofer volume, some factory settings are set @ zero.
Sep 09, 2008 | JVC TH-M55 System
Jvc th-m45 shut off
shut off audio system is performed to protect it from damage due to high current consumption or short circuit in speakers try to disconnect subwoofer first and check if it is ok. the problem in your subwoofer or its cord-change the cord and check if it is ok thats fine if not change subwoofer.do the previuos for all speaker one by one.
if all above failed you must contact service center for help.
Apr 06, 2008 | JVC TH-M45 System
Jan 12, 2008 | JVC TH-M505 System
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=30&modelId=MODL027222
cut n paste the link for the manual
Are headphones plugged into it?
Is the headphone jack damaged?
Are there speaker fuses on this model? If so, check them.
Dec 06, 2007 | JVC TH-M505 System
Th-R1 no pwoer to subwoofer - transformer u/s?
my power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Oct 14, 2007 | Audio Players & Recorders
SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Oct 21, 2006 | JVC TH-M505 System
Subwoofer JVC TH-M606
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
May 19, 2006 | JVC TH-M606 System
150 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
