Question about Panasonic Microwave Ovens
How to reset a Panasonic inverter the genius sensor 1350 W that read p10 error
SOURCE:
MicrowaveSvc
  • 9173 Answers
SOURCE: I Need a replacement glass for a panasonic
That's not the model number of the oven.
Check the tag around the control panel frame. It will be something like NNS-542BAW, etc.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 24, 2009
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Posted on Apr 24, 2010
SOURCE: panasonic inverter genius sensor 1250w, turns on
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Posted on Mar 01, 2011
MicrowaveSvc
  • 9173 Answers
SOURCE: Panasonic Inverter Genius Sensor 1250W reads code H97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Nov 03, 2012
  • 136 Answers
SOURCE: Why does the plate on my panasonic inverter genius sensor 1250w microwave not spin?
Try this link:
Posted on Sep 28, 2015
WHAT DOES THE MESSAGE P10 MEAN
Most of the time P relates to Power. Microwave cooking Power at level 10. P10 is most likely the highest cooking power setting. If this is in error - Google the information - Or youtube it..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Aug 05, 2014 | Panasonic Black 1300-Watt Counter Top...
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
Nov 02, 2012 | Microwave Ovens
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 26, 2010 | Panasonic Microwave Ovens
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
Feb 09, 2010 | Panasonic Microwave Ovens
Error code H-98
Dec 01, 2008 | Panasonic NN-P794SF Microwave Oven
Scrape or fix? Panasonic inverter genius sensor 1250 watt
In most cases, this is a problem with the inverter but it may be a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
