Question about Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Problem
Could not turn on power for screen, but speaker are alway on.
is it powr supply problem? or TV turner burned?
  • Anonymous Dec 09, 2007
    TV power button clicks on but shuts itself off right away before TV picture comes on TV. Was watching a DVD and it shut itself off in the middle of movie.
  • cbuddy2005 Apr 06, 2008
    clicks on and off and only the green light is illuminated--and this is only for a second
It the circut board that is connected to the power cord ,
Posted on Mar 26, 2008
Mitsubishi Medallion WS-65819 wont turn on. Code 2-2
The power supply regulator section circuit inside should be troubleshooted.
Mar 28, 2013 | Mitsubishi WS-65819 TV
My Mitsubishi ws-65819 shows in an oval shape, can this be fixed, also is there a way i can do it myself to save some money? Also how to play an Xbox 360 in HD? can rplace the convergence ic's on convergence module......these are the big stk type ic's and also the low ohm resistors.
These are 3.9 to 6.8 ohm half watt on the yoke return circuit. Let me know how you fare......regards. meder's tv
May 28, 2012 | Mitsubishi WS-65819 TV
My Mitsubishi ws 65819 won't turn on. When I unplug the tv and plug it back in the small light under the word timer flashs but that's it
its in high voltage shutdown. if ya wanna cheat? it'll take a dimmer type switch to cut the voltage in half. slowly till u can turn it on. then full voltage. if it is in high voltage shutdown you then need a technicians eye 2 see the symptom thats causing the problem. remember the shutdown is caused thru a saftey mechnism, and don't burn the house down. my 1000 mile away diagnosis says your voltage regulator or horizontal is out. most problems are power supply related, thus the voltage reg. is bad. if you use a higher current dimmer switch ...its a cheater tool that technicians can use, so be carful. keep an eye on all cords...heat should not be present in any appliance , etc. thats the wire to the wall.
Nov 22, 2010 | Mitsubishi WS-65819 TV
My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Dec 03, 2009 | Mitsubishi WS-65819 TV
Cant turn the TV speakers on
May 20, 2009 | Mitsubishi WS-65819 TV
I cant turn the tv speakers on
You should be able to go to the main menu and select the setup menue, from there you should see the internal tv speaker option. Here isthe link to the manual:
The tv does power up at all, we need a new micro-processor board
There are 23 Parts available from =>
Maybe they have the part you are looking for.
This website for Mitsubishi has only 4 parts for the model =>
Dec 30, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 Sender Board problem
yes it can the cost is $350 sumwut dollars ,i got my tv for $54 and thats wut was wrong with it ,the board that is connected to your power cord is wut needs to be replaced sears can do the job but the labor is $200
Nov 30, 2007 | Mitsubishi WS-65819 TV
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
