SOURCE: panasonic cordless won`t dial with magic jack
Turn off your LOCAL AREA CODE entry in the Panasonic... Magic Jack WANTS the area code to ALWAYS be dialed... so store incoming caller ID's with the AREA CODE INTACT and dial only from numbers with an area code displayed. Worked for me!
SOURCE: Headset has static
Perform a reset on the headset. Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times. Release both the mute button and the call answer button. See if it works now. If it doesn't, try a re-subscription (should be available in the manual).
SOURCE: continuous dial tone on phone line
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
SOURCE: I had two SoundstationEX phones
yes do a full reset and reprogram for new phone number and all settings when you move phones
Hi leroy rolle, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
