Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Jenn Air Range SCE30600
I do not have an f5 error code. I have an Off error code. Oven will not go on. Stove top elements and timer/clock are still working.
  • Jenn-Air Master
  • 2,651 Answers
Re: Jenn Air Range SCE30600
I would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Posted on Feb 23, 2008
0 characters
3 Points
Jenn-Air oven shuts down after FC and F5 errors
Their was a good possibility that the solder could have been lifting of the contact points on the board, if the symptoms return i would check this, along with the said cleaning method :)
Mar 15, 2014 | Jenn-Air SCE30600 Slide-In Electric...
I just replaced front control panel but when I turn on oven to bake it flashes an F5 error code. What is the problem. Could the new control panel be faulty?
This is probably because of a poor connection on the relay board, or a bad sensor connection. If the f5 error code was not the original problem (and just appeared since you installed the new panel) you probably did not connect the harnesses exactly right.
Mar 25, 2011 | Jenn-Air SCE30600 Slide-In Electric...
Jenn air range model SCE30600B error code FC blinks with beeping noise. After resetting the temp down to 350 to keep from burning a pizza error code FC started blinking along with continual beeping. I have...
replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
Feb 03, 2009 | Jenn-Air SCE30600 Slide-In Electric...
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
Range/Stove/Oven Fault Codes
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
'Newer Style' Range/Stove/Oven Fault Codes
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven element
bad relay on erc(electronic range control), or and open thermaostat wired in line with element you would need to pull unit and check wiring
Feb 07, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
331 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
