Question about Google Computers & Internet
My tv comes up with an error message that says" the operation with control is prohibited" . But I can control the tv with the google home app with the chrome cast and the volume is set at very low.
  • 798 Answers
Try to rest the TV
Posted on Jan 14, 2019
  • Peter Dragonetti Jan 14, 2019
    sorry : Try to reset the TV
SOURCE:
  • 42 Answers
SOURCE: Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
Posted on Jan 04, 2009
SOURCE: Connection problems with Panasonic Viera Cast
I have had the same problem with my Panny DMR-BS850 which was resolved by changing the ethernet cable I was using which had only 4 contacts on each plug end for one which has 8 contacts. I tried all variations & combinations of IP & DNS before buying the new cable from my local pc store (£10 for 10m cable) and was relieved when setting the system to auto connect it worked within 3 mins. I think the slight delay was the router setting up a new address for the new hardware it detected.
My new cable states on it "Verified For Gigabit Ethernet" and is Cat 5e rated and I was assured that it will carry data for runs up to 95m long, which is contrary to the Panasonic support agent who told me to shorten my initial 5m cable to prevent signal degradation.
Give it a try.. it might just work.
Posted on Jul 21, 2009
  • 173 Answers
SOURCE: it wont load facebook and other pages, keeps
with google chrome open press Shift + Ctrl + Delete key at the same time when new window opens go to the Clear data from this period and select last 4 weeks make sure that all is checked off except for passwords this should clear up your issue
Posted on Nov 03, 2009
Testimonial: "it was helpful info, but the problem is not 100% still comes up with error message sometimes and pages are very un-organised and *****"
Schmead10
  • 652 Answers
SOURCE: Google chrome has a Error 10
uninstall and reinstall
Posted on Jun 28, 2010
  • 13 Answers
SOURCE: Error 118 (net::ERR_CONNECTION_TIMED_OUT): The operation
I got this all the time due to low bandwith, normally that happens if your connection to the internet is maximized in a way that you are downloading big files at the same time you are surfing the net with lots of tab on the browsers. you may just manage the usage of your bandwith wherein you need not to multi task, if the scenario is not applicable to your connection in which no download is in progress and you are just surfing the net cleaing the cache will fix the problem. you just need to click on the wrench icon on the upper right hand corner and select options > under the hood > clear browsing data. close the chrome browser and reopen it again. hope that helps :-)
Posted on Feb 25, 2011
All power windows not working 2008 saturn outlook ?
Which of these does your vehicle have ?
Power Windows Description and Operation (W/O AXC/AXE)
Power Windows Description and Operation (RPO AXC/AXE)
Do you know what a RPO code is ?
http://www.gmc4x4.com/topic/305-deciphering-the-glovebox-rpo-codes
http://www.rpocodes.com/rpotaglocations.html
Need to know which one because one is basic an the other has electronic modules involved , driver door module , BCM - body control module , passanger door module etc..... Both power window circuit's use a circuit breaker an not a fuse . Would not think that being the problem . Broken wire's inside the flex boot from the body to the door maybe.
Power Windows Malfunction (AXC/AXE)
The front and rear power windows are controlled by the driver door module (DDM) and front passenger door module (PDM). The DDM and PDM each contain power window switches that are integrated into the module. The DDM contains the master power window switches that control all power window operations. The power window switch contained in the PDM controls the front passenger window operation only.
When the driver power window switch is activated to a desired position, the DDM examines the request and checks for messages from other vehicle control modules prohibiting window movement. If no prohibitive messages have been received, the DDM will send a serial data message to the driver door window motor to move the window to the desired position.
When the DDM receives a request to operate the right side passenger windows from the master switch, a serial data message is sent to the PDM. The PDM examines the request and checks for messages from other vehicle control modules prohibiting the window movement. If no prohibitive messages have been received, the PDM will send a serial data message to the appropriate window motor to move the window as requested.
When the DDM receives a request to operate a rear window from the master switch, a serial data message is sent to the BCM. The BCM examines the request and checks for messages from other vehicle control modules prohibiting the window movement. If no prohibitive messages have been received, the BCM will send a serial data message to the appropriate rear window switch which will command the window motor as requested.
Power Windows Malfunction (Except AXC/AXE)
Circuit/System Description
The power window system will operate any time the ignition is in the ACC or RUN position. The power window system will also operate whenever the body control module (BCM) is in the retained accessory power (RAP) mode. The driver power window switch contains individual window switches for each of the power windows. All windows may be controlled up and down from the driver master control. The individual passenger power window switches will only control the up and down operation of their respective power window.
Each power window contains a reversible power window motor. The direction the window travels is dependent upon the polarity of the supply voltage. By reversing polarity of the supply voltage the window motor will move up or down. Each power window motor is internally circuit breaker protected.
Battery voltage is supplied to each power window switch through the accessory voltage supply circuit. The power window switch also receives a constant ground source. The power window motor control circuits are connected to ground through the normally closed up and down contacts of the power window switch. When the power switch is placed in the down position, the power window motor down control circuit is switched to 12 volts and is applied to the down side of the power window motor. Since the other side of the power motor is connected to ground through the normally closed contacts of the up switch, the window travels down. By placing the power window switch in the up position, the polarity of the power window motor is reversed and the window travels up.
Jun 19, 2018 | Saturn Cars & Trucks
Network error message using google search
You need to register this device to the app store
Dec 28, 2013 | Universal MK809 Dual-Core Android 4.1.1...
The operation with remote control is prohibited
What is the exact Brand name and Model number to your TV?
Aug 15, 2012 | Televison & Video
Trying to load Google chrome and I get 0xc0000a5 app wont start error
Hi There
You do not mention your Operating system, or specs of the computer. That error message is normally a RAM message indicating that part of RAM cannot be read. It might also that your virtual memory is low. Try closing alother applications then run Google Chrome again.
Andre
Sep 17, 2011 | Computers & Internet
I can't move the channel selector on the remote up or down. I can depress the control but nothing happens. I can key in the channel number OK but to change channels I have to key in another number. The...
when I press any buttons on remote control cant move the channel and there is a message showing on tv screen "the operation with remote control is prohibited
Feb 23, 2011 | Sharp RRMCG1687PESA Remote Control
I tried aending an attachment on my yahoo account but gmail prevented it from being processed !!!???? I contacted them but they do not answer How can google screw up yahoo? I do have a google account and...
What was the exact error message?
What was the extension type of the attachment.
All email services prohibit processing certain file types, such as: .exe .bat .reg .rar .cmd .com and many more; because they can possibly cause harm to the recipient's computer.
Also prohibited are very large files, such as ones over 5MB, or a combination of attachments that exceed the supported size.
Please comment and perhaps we can determine a fix for this issue.
Oct 17, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Oct 29, 2008 | Sharp RRMCG1687PESA Remote Control
Computers & Internet Logo
Top Google Computers & Internet Experts
Peter Dragonetti
Colin Stickland
Colin Stickland
George Etukudo
George Etukudo
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
