Actually my Epson printer not printing black ink and I want how to fix that issues.
Hello, Mick -
What is the model of your Epson printer? You can choose Comment and add the model number or name there.
Since I have no idea what model of Epson printer you have, I also have no idea if your printer just is a black ink printer or if it can print in more than just black.
Some options regarding your problem:
* Your printer has run dry of black ink and needs a new black ink cartridge or an ink refill.
* One or more of the color inks for your printer have run dry and you need to replace the color ink cartridges with new ones or refill the color ink reservoirs.
If your printer is meant to print in both black and other colors (magenta, cyan, yellow), then, you need to know that the 3 colors are used and mixed with the black ink to make black print. So, for a color printer, one needs to have all 4 ink cartridges filled with adequate ink.
Best wishes.
SOURCE: Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
SOURCE: Black ink not printing and colour ink very faded
Check the ink status of the printer's cartridge.
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
SOURCE: Using colour ink without black ink in Epson CX5500
this cannot be resolved, Epson software is useless it will force you to buy an INK
