Question about Vulcan EF3 Deep Fryer
CAN'T GET UNIT WORKING CORECTLY
CONVERTED TO LP HOOKED UP TANK THE PILOT STAYS LIT UNIT COMES ON BUT DOES NOT STAY ON I USED WATER IN TANK SO AS NOT TO BURN UNIT UP I;M A NEWBIE TO DEEP FRYERS
  • ROBERT288 Nov 29, 2007
    NEW ORFICES NEW PILOT NEW PART THAT WENT ON GAS VALVE THE PILOT STAYS LIT UNIT WILL COME ON SOME TIMES WHEN I TAP THE THERMOSTAT OR SUPPLY LINI WHERE THE BURNER TUBES ARE
  • ROBERT288 Nov 30, 2007
    NO I DIDN'T CHECK THE PRESSURE THE PARTS PLACE I GOT MY STUFF AT SAID THAT ALL I HAD TO DO WAS INSTALL PARTS HOW DO YOU CHECK THE PRESSURE
Hi, my wire connection ( hi-limit/thermostat/thermocouple) is incorrect, I wonder , if u could help me please.
Posted on Jul 24, 2008
  • 640 Answers
What parts did you replace to do the conversion? Make sure all your wire connections are correct (hi-limit/thermostat/thermocouple connections).I repair these fryers if you need more advise let me know.
Posted on Nov 29, 2007
  • 1 more comment
  • anthony james
    anthony james Nov 29, 2007
    Does the pilot flame look good?Did you check the gas pressure?It needs to be about 10 inches,Natural gas is 3.5 inches of water colum.let me know
  • Frank
    Frank Oct 23, 2013
    i have a problem with my double basket LPG Fryer. When i start my fryer in the morning it starts fine and heats up until the set temperature and then flame shut of as it should.BUT it never starts again when the temperatur falls, maybe after one hour or so it starts again.
  • Frank
    Frank Oct 23, 2013
    P.S the fryer was bought from ACE but its a made in China :-( fryer the model is GF-182
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
5yr. old aquastar 125x lp wont stay lit after about 5min. use. just started happening out of the blue... a clicking noise preceeds the flame shutting off. any ideas?
The gas valve makes a single click sound when the pilostat shuts off. That is a safety holding coil for units with standing pilot lights and closes if it thinks the pilot went out. In electronic ignition, the same holds true except the sensor is electronic.
Mar 31, 2011 | Bosch & Tankless LP Hot Water Heater
Piloit won't stay lit.
I would check to make sure thermocouple is in proper position in pilot flame. If so and pilot won't stay lit I would replace thermocouple. Thanks
Nov 12, 2010 | Bosch & Tankless LP Hot Water Heater
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Jan 19, 2009 | Mr. Heater (F274825)
Pilot will stay lit but will go out when unit is turned to low
is the pressure regulator right for the type of gas your using...? i had the same problem.i found out that my regulator was for both lp and nat.gas.i also found out there is a small nylon pin underneath the brass cap on top of the regulator.i unscrewed the cap and the fitting was set for lp.and i was using nat. gas.i just pulled the nylon pin out,flipped it around and replaced the cap...works fine now.if your regulator is like mine the nylon pin is maked LP on one end and NAT. on the other.might be worth a try
Nov 27, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Vulcan EF3 Deep Fryer Logo
200 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
