Question about Sony KP-51HW40 51" Rear Projection Television
Sony kp-51w5510 rear projection tv convergence
My friend gave me a big beautiful tv really cheap but it has a slight problem:the pattern of crosses lines up according to manufactures specs: two rows of crosses tight towards the top of the screen, and four evenly spaced rows across the rest of the screen. from there I have two problems. first, the ends of both sides seems to bend down. the second problem is the red cross is too far right to bring the three colors together using the remote control for adjustment. I run a union woodworking crew and have for ten years so I am mechanically inclined. (I think). I took the back off the set just to see if I could wrap my brain around it. I found that adjusting the focus of the three colors was quite simple. Loosen the wing nut, make slight turns and whallah. nice focused color. My problem is that I expected there to be a left and right adjustment for the red bulb that would jump out at me just as easily, and of course ....it did not. Let me know if you can help, any advice would be greatly appreciated.
tony
I have a sony kp51w5510 tv. It appears to have ghosts with a red hue. What should I do
Posted on Nov 07, 2009
    Problem Solver:
Take off the front speaker cover (2 screws) then take off the cover in the middle which has 4 screws. now you can see the 6 adjustment screws. the far left is the blue and middle is the green and right is the red.
Posted on Dec 05, 2007
    Genius:
  • 1,694 Answers
Lateral red or blue movement is accomplished electronically
via convergence alignment circuitry controlled by STK type IC's
Replace them both for reliability, then adjustments will work..
Posted on Dec 04, 2007
Sony kp-51w5510 colors are bowed down
Thats almost always a convergence circuit failure. Installing a convergence repair kit should solve the issue. Your model uses the Sony #1 convergence kit whichh comes with the parts and the CD with repair instructions and its available at the following link. http://tvrepairworld.com/convergence_repair_kits/sony_convergence_kits
Apr 02, 2013 | Hitachi 53UDX10B 53" Rear Projection...
I have a Sony KP-57WS510 and am having problems converging. The red works fine however the blue cross on the outside colums of the convergence pattern is off to the left. I am unable to move these blue...
The tv convergence board it is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.U have all the tools and also can do soldering ICS works?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a complete convergence kit parts for ur tv model and repair it ur self.Or the tv shop,will cost u like $300-350 for parts and labors.
Apr 23, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Our 7 year old Sony TV KP-51W5510 has the following problem. Picture has 2 colors, writting has 2 colors the skin tone has 2 colors, writting on the screen will show 2 colors black and red in shadows pls...
a ladha,
You have lost the convergence circuitry. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will explain the problem, tell you where to get parts and explain how to do the repair.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a 7 year old Sony KP-51W5510 rear projection tv. The right side is all yellow and the left is all blue. In the middle the colors line up but gets worse towards the left and right. My convergence...
No.This problems it not the projection lamp problems.Yes,this problems is the tv convergence board problems,it dead.The tv convergence board the 2 STK covergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the convergence problems.U have tools like a soldering iron,desordering pump,know basic electronic and soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Or the shop will cost u $300-350 for parts and labors.
Sep 04, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a Sony Model KP-51WS510 Rear Projection TV. My convergence STK need replaced the only parts I could find are STK392-150 (18 prong) when I removed the existing STK parts they are STK392-560 (18...
dont know if they cross or not but do know that (Mat electronics has the stk 392-560 fo 10.50 apc phone number is 1 800 628 1118. just to let you know. Also there is some small fusses that need to be checked to see if any are open they are right under the heat sink where the ic are at and are usly yellow in color 3.5 amp i think plus the restors need to be checked. They should read 1.2 ohms in value there is serivale under the heat sink also. Hope this helps you out.
Dec 05, 2009 | Sony KP-51WS510 51" Rear Projection...
Standby red lamp on my KP-51W5510 blinks in an 8 blink pattern
Try this first HOLD DOWN THE RESET on the remote while pressing the power button on the TV.
If this does not restart it one of the IC chips has failed and it will require repair
please rate this help top keep our service online
Aug 17, 2009 | Sony Grand WEGA KDP-51WS655 51" Rear...
How to change convergence ICs in Sony KP-57WS510 TV?
Replace Both STKs convergence ICs big black ics with number on them STK392-560.Parts 1-800-223-3205
Dec 20, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony big screen tv
ALL of you have bad convergence ics replace them and set will be fixed, STKs 2 of them big black ICs
Mar 30, 2008 | Sony KP-51HW40 51" Rear Projection...
SONY KP 413SU
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Dec 06, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
916 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
