Question about Garmin StreetPilot c550 GPS Receiver
Garmin streetpilot c530
My garmin wont aquire satellites and i have the most updated software and i tried resetting it but it still doesnt work
  • msuriano Dec 16, 2007
    Ive reset my c530 several times and I keep getting the message:
    "No detailed maps found that support routing. The Streetpilot cannot be used without them". There are no buttons to push or anything - Can anyone help?
Try calling their main number in Olathe, Kansas 1-800-800-1020 - i had the same problem with mine after we had gone online, registered, and downloaded updated software. The sucker would not find satellite signals. I ended up shipping mine back today - hoping they will fix it and send back quickly. The tech guy I worked with over the phone was extremely polite and walked me through some steps that should have solved the problem.
Posted on Dec 20, 2007
Garmin 200w has trouble aquireing satellites?
Go to the Garmin dot com website and follow prompts to download the software and the firmware and software updates - they are free.
Jun 12, 2010 | Garmin nuvi 200W GPS Receiver
I updated the software, and now it takes a long time for satellite aquisition. Can I roll the software back?
Not usually caused by an update.
Try recharging the battery to capacity or even having the battery changed. Low power will delay connection time
Jul 22, 2009 | Garmin StreetPilot c530 GPS Receiver
How to reset garmin c530? thanks.
Pull the face off, press reset button under it,
then update it at Garmin's Web-updater website.
If it wiil not reset like this
Press the lower right corner of the screen, while turning on, keep pressing until the message
" do you want to remove all data " appears, click yes
Then re-register it at Garmin, then re-update it at Garmin
Should be good then
May 18, 2009 | Garmin StreetPilot c530 GPS Receiver
Touch screen doesnt work all the time
Pop the face off to reset it, could sort it for you.
Press the power button for over 1 minute to calibrate the screen
and use the Garmin Web-updater to update the software.
Should be good then
Apr 15, 2009 | Garmin StreetPilot c530 GPS Receiver
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still exists then try to charge your gps from any external charger and check whether screen is working properly .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Dec 09, 2008 | Garmin StreetPilot c530 GPS Receiver
Cant find satellites
same problem the acquiring satellites appears with a flashing '?' some where in central london 'horseguard', ......the unit switches on and off i have reset it used hard and soft reset methods.....updated the unit....same problem....
garmin streetpilot c510 delux model
Apr 07, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Reset my garmin streetpilot c530gps
There is no way to just "reset" the PIN. If you don't have the correct PIN, you must take the unit to the location at which the PIN was set. Your only other option is to return the unit to Garmin.
Feb 21, 2008 | Garmin StreetPilot c530 GPS Receiver
Unable to acquire satellites after a software upgrade.
Have you tried downloading the update again? It's possible it did not download correctly, If this doesn't work, it may be possible to download the previous version again.
Jan 06, 2008 | Garmin StreetPilot c550 GPS Receiver
No signal
There are three forms of resets on the unit.
The first is the reset under the front face plate. The second is where you hold the power button for a long time (30 seconds).
The last and potentially warranty voiding solution is to pull off the front face plate. Remove the four tiny philips head screws. The front face plate can now be lifted off. There you will see a battery and a little connector with 2 or 3 wires attached to it. Disconnect it. Wait a while... 30 seconds.... 30 minutes... overnight.... and plug it back in.
I've read some reports about the web updater software flaking out, so I recommend flashing through the SD card slot if possible.
Nov 26, 2007 | Garmin StreetPilot c550 GPS Receiver
No signal
Try and replace the antenna
Aug 11, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
121 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
