Question about Teac SL-A100 Turntable
TEAC SL-A100 Seems to play to fast
I have a TEAC SL-A100
and it seems to play to fast. Is there a way to slow the speed down besides the 3 postion switch '33-45-78'?
  • Anonymous Nov 11, 2008
    I've noticed this too. It gains about 20 seconds every five minutes on 33 (more or less). Nothing that I know can be done though. We get what we pay for.
CompuGuy44
  • 432 Answers
SOURCE: only spinning at 1 speed
This is a high dollar turntable. If you want, take the screws out, open it up and check that the direct drive speed gear is in place. Other than that I would take it to a repair shop. There's one guy on ebay selling a new one for $500.00 http://cgi.ebay.com/Technics-SL-1200MK2-Manual-Direct-Drive-Turntable-New_W0QQitemZ320132536688QQihZ011QQcategoryZ64448QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on Jul 01, 2007
  • 7 Answers
SOURCE: Ion turntable speed problems
yes, first you have to microwave it, that works
Posted on Nov 08, 2008
SOURCE: Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Posted on Feb 02, 2009
  • 189 Answers
SOURCE: The speed on my JVC L-A11 is too fast when set to
HELLO
There a few things which can cause this problem. First the speed change switch may be faulty or contaminated by dirt/dust. If I were looking at this deck I would spray some Servisol switch cleaner into the switch (you may have to remove the base of the deck to do it).
There should also be two variable pots which are used to set each speed - spray those as well - it may be a "dead spot" on the pot itself. These are the most obvious causes but if the problem still persists check the belt. If that is OK, then you may have a fault in the speed control circuit.
ALL THE BEST WITH IT (:-)
Posted on Oct 04, 2009
Grubhead
  • 5348 Answers
SOURCE: teac turntable plays too fast
This sounds like a motor speed control problem. It could be either the motor itself or an electronic fault. So unless you know a bit about electronics and know how to use a soldering iron etc, then the answer to your question is no.
Posted on Oct 24, 2009
How do I fix the speed of my Technics SL-6 Turntable?
Something has gone awry in the world beneath the platter so you will have to remove the platter to expose the mechanism, then observe what happens (or doesn't happen) when the buttons are pressed.
Jul 29, 2014 | Technics Audio Players & Recorders
Needle sliding
Going on what little you have written, the most likely cause is a worn or bent needle. http://www.turntableneedles.com/search.asp?keyword=793-d&search=GO is the needle type that should be correct for your Teac SL-A100 Turntable.
Feb 16, 2013 | Teac SL-A100 Turntable
Turntable slows down and stops
If it has a belt drive, the belt has stretched and needs to be replaced.
Oct 07, 2012 | Teac SL-A100 Turntable
TEAC R-H300 Forward Play Fault
The unit need some work by a technician. The bad thing about the drawer type decks is that it makes it hard or impossible to clean the tape path. I have not seen one of these but I could probably fix it.
Some of your description sound like a loose capstan belt and then other times the Pinch roller is not engaging- they may be related if the mechanism is tied to the capstan motor system.
Sep 11, 2012 | Teac R-H300 Dual Cassette Deck
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
May 15, 2011 | Teac SL-A100 Turntable
My Teac sl-a100 record player sounds like a chipmunk
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
Apr 30, 2011 | Teac SL-A100 Turntable
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running...
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Sep 21, 2010 | Technics SL-BD22 Turntable
Turntable plays too fast
I have seen this problem before. Lift the turntable off. It might be held down with a clip around the center pole. Under it you will see a wheel that contacts the turn table and the center shaft of the motor. The motor shaft has 3 0r 4 elevations with different diameters. When you change the speed the wheel will move up and down to different diameter levels on the motor shaft. It must be free to move. It might need some oil at the moving parts as I suspect it is not moving properly.
Hope this helps.
May 08, 2008 | Teac SL-A100 Shelf System
Stopped turning
Try removing the cover and looking for a broken belt. Make sure that the motor is spinning too. If you find a broken belt, let me know and I'll help you find a replacement.
- Jim
Jan 28, 2008 | Teac SL-A100 Turntable
Teac SL-A100 Turntable Logo
127 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
