We have a power cut how do I open the machine
    Top Expert:
  • Washing Mach... Master
  • 5,708 Answers
Model # please?
Posted on Oct 21, 2018
Washing machine does not resumes from where it pause after the power cut. Washing machine model is WAX16161IN. Is there any fault?
it would be unlikely to have a memory setting
normal machines start at the beginning and work through the program
if there is a reason for the pause 9 out of balance , door/lid opening or just pause to go out) that would be held because there is still power to the program board
however on a power outage , it would not know where it was at in the program
Jun 06, 2016 | Washing Machines
Washing machine cuts out
The pump is over heating and cutting power.
Mar 30, 2012 | Fisher and Paykel Washing Machines
PAG2200D angle grinder has 2 guards.One is a half guard,the other covers both sides of disc. Which one is used for grindins,which for cutting?
The double sided guard is the one for cutting and the single sided one is to allow you ot use the flat side of the disc for grinding. (Do not use cutting discs for grinding, on these discs use only the very edge of the disc and always wear protective eyewear and gloves. Never allow the stationary machine to rest on the disc, lay to rest with the disc facing upwards and disconnect the power lead when replacing discs etc. These are very dangerous power tools and should be treated extremely carefully).
May 26, 2011 | Saws
I had a power cut at the end of the cycle on my whirlpool 295 front loading washing machine, this machine is, I think, approximately 12 years old. everything is working , completing all cycles, but the...
Hi just read your posting.There are 2 common reasons your door will not open and they are,The handle on the door is broken or the door lock that is attached to the machine is faulty and not releasing. Did you try turning the machine off at the power point? Have a good look at the handle of the door and see if it is broken.My best guess on the problem with your machine,noting you had a power cut , is the door lock is the part that is faulty.The only way to fix this problem and release the door is if you remove the lid.If you would like me to help you reply back and I will guide you step by step to rectify this fault.Good luck and hear from you soon.
May 14, 2011 | Washing Machines
My 'k' pressurewasher keeps cutting out
Dear Sir,
The power washer stops when the gun is closed. This happens because pressure is exerted on a control valve (Spill Valve)...which in turn touches a micro switch and cuts electricity. Now most probably your machine is cutting out because the spill valve is getting faulty or stuck down and closing the micro switch. This happens when one stores away the machine with pressure still in it. NEVER store a power washer with pressure in it. The spill valve also gets gammed and faulty because left with soap and machine not rinsed. I rarely service spill valves...I change with a new one.
To locate the spill valve open cover (using a TORX T15screw driver)...and where you see 2 wires coming out...there is the spill valve. If you can manage to do this..you can try if you want to lubricate it by spraying SILICON spray. If you get it out..you use silicon grease.
Sometimes these machines have the spill valve incoporated with the head....in that case the whole head must be renewed. I wish to tell you to try using the machine without the lance. If it works correctly, then you have a faulty nozzel in the top of the lance. IMPORTANT...never run a power washer with water being fed!!!!
Regards,
Fulltech.
Mar 15, 2011 | Karcher K2.26 Electric Power Washer
The machine cuts off power as it tries to print the ekg
hi,
Change the battery, will solve your problem. Its a 12v battery. For replacing the battery you have to open the ecg machine by removing the screws at its bottom.
ok
Feb 26, 2011 | Schiller Welch Allyn Cardiovit At 2...
The power paw on my vacuum machine is not working.Eureka ez kleen
The filter is not the reason it's not working. Take out screws and open Power Paw, remove fur from the roller brush on the right side, there is a small gap where fur winds around tightly, cut off with scissors or pull out with a small toothpick.
Oct 18, 2009 | Eureka Vacuums
No power to machine - there is power to the plug
I had the same thing happen. I took the top off and realized that the power cord from the factory went out the back.....back in an opening.....across the back but on the inside and out another opening. The part crossing the back on the inside was near the motor and belt and was cut through the hot wire and ground. Someone has to be an idiot to run the wire in the design on the inside.
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
453 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
