Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Error code brand new just installed it and i get an ER and then flashes uo 4000 series aquasurgefrigidare
  • tschwei122 Dec 08, 2007
    Same problem..don't get the UO just he ER and it flashes. Less than 1 year old
  • Anonymous Mar 16, 2014
    it says er then uo??
  • 3 Answers
We had the same problem with our Frigidaire dishwasher (different model though). We called them and they said the UO stands for Vent Open (the display can't make a V so it makes a U). The active vent was not closing when it should be closed (the repairman said the gasket was stuck up in the assembly so sometimes it would seal and sometimes it wouldn't) and thus the error. Since our machine was still under warranty, we had the vent replaced at no cost and haven't had the problem since.
Posted on Dec 29, 2007
Our is brand new as well is this a vent that we fix or do we have to wait for repair man?
Posted on Oct 26, 2008
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
Frigidaire dishwasher error code
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
Jan 19, 2013 | Frigidaire Dishwashers
I just installed a new Frigidaire dishwasher. Took it through 1 cycle as the directions indicate looking for leaks. I now have it full of dishes for its maiden voyage, and I get an Er uo code. Cannot find...
this is a vent problem you need to check the vent motor and make sure tha the wire have not been pinched by the door spring and make sure it is connected properly.the vent should be located on the top or possibly the right side of the cabinet.
Feb 07, 2010 | Dishwashers
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Frigidaire 4000 series dishwasher error code
This is likely an indication of a problem with the circulation pump motor under the dishwasher like maybe a bad circulation pump motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Error code ER then UO any ideas?
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Apr 22, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
927 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
