Question about Microsoft Office Professional 2007 Full Version for PC
PowerPoint 2007 presentaion view exits to slide sorter view.
When running a presentation power point will exit to slide sorter view. This is a reoccuring problem that happens several times during the presentation. The only change made to the computer has been a internet security download from CA. The application was OEM install on a new Acer computer with 2 gig memory.
Dear jdom, there is because you've made the default view slide sorter. you can change this by going to
Toos>options>view> open all files in this view> select default there by choosing your preference.
if this has solved your problem please click solved.
Posted on Nov 26, 2007
I want to open powerpoint presentation.
then, go to format -> slide design, choose to show all documents, and choose the corrupt powerpoint file. now, go to insert -> slides from file, and select the corrupt powerpoint file. make sure you are set to insert all slides, and then import. if that works, great! i suspect, however, that you might crash at that point. if so, try repeating the process, inserting specific slides one by one until you find the problem one. after that, save the file, making sure that fast saves are off (in preferences / save).
if you are unable to open your powerpoint files then try pptx viewer tool. this utility recovers your corrupt and damaged powerpoint presentations (.ppt, .pot, .pps, pptx and ppsx formats) from ms powerpoint files.
Jan 19, 2015 | Microsoft PowerPoint Computers & Internet
How do I view sidebar on Microsoft Powerpoint? I have a Compaq laptop and whenever I open to view a powerpoint only the full slides pop up, but I can't view the sidebar. I don't have Microsoft powerpo
If you don't have powerpoint installed, then you're probably using the free viewer, or it's a power point 'show' (the viewer is built into the presentation). You can print the slides, but not the individual notes or key pages. One thing you could try is if you have a Microsoft/Hotmail/ account, you may be able to open it and print from there. I'm able to do it with a regular presentation, but it might be different with a show. To do this, log into, click the menu in the top left corner, and click Power Point Online, then just upload the file you want to open.
Oct 28, 2014 | Microsoft PowerPoint Computers & Internet
How to make power presentatio?
  • If Office PowerPoint 2007 is already running, save and close any open presentations, and then exit and restart PowerPoint 2007.
Find links to information about saving presentations in the See Also section.
  • If Office PowerPoint 2007 isn't already running, start it now.
In the Slide pane, you can work directly on individual slides. za001093949.gif Dotted borders identify placeholders, where you can type text or insert pictures, charts, and other objects. za001093950.gif The Slides tab shows a thumbnail version of each full size slide shown in the Slide pane. After you add other slides, you can click a thumbnail on the Slides tab to make the slide appear in the Slide pane. Or you can drag thumbnails to rearrange the slides in your presentation. You can also add or delete slides on the Slides tab. za001093951.gif In the Notes pane, you can type notes about the current slide. You can hand out your notes to your audience or refer to your notes in Presenter view when you give your presentation. Note By default, Office PowerPoint 2007 applies the Blank Presentation template, which appears in the preceding illustration, to new presentations. Blank Presentation is the simplest and most generic of the templates in Office PowerPoint 2007. Blank Presentation is a good template to use when you first start working with PowerPoint because it is straightforward and can be adapted to many presentation types. To create a new presentation that is based on the Blank Presentation template, click the Microsoft Office Button za010077102.gif, click New, click Blank and recent under Templates, and then double-click Blank Presentation under Blank and recent.
After you open the Blank Presentation template, only a small portion of the Notes pane is visible. To see a larger portion of the Notes pane so that you have more room to type in it, do the following:
  1. Point to the top border of the Notes pane.
  2. When the pointer becomes a za010205206.gif, drag the border up to make a little more room for your speaker notes, as shown in the following illustration.
Name and save your presentation As with any software program, it is a good idea to name and save your presentation right away and then to save your changes frequently while you work:
  1. Click the Microsoft Office Button za010077102.gif, point to Save As, and then do one of the following:
    • For a presentation that can be opened only in Office PowerPoint 2007, click PowerPoint Presentation.
    • For a presentation that can be opened in either Office PowerPoint 2007 or earlier versions of PowerPoint, click PowerPoint 97-2003 Presentation.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
  1. In the Save As dialog box, in the Save in list, select the folder or other location where you want to save your presentation.
  2. In the File name box, type a name for your presentation, or do nothing to accept the default file name, and then click Save.
Add, rearrange, and delete slides The single slide that is provided automatically in your presentation has two placeholders, one formatted for a title and the other formatted for a subtitle. The arrangement of placeholders on a slide is called a layout. Office PowerPoint 2007 also provides other types of placeholders, such as those for pictures and SmartArt graphics.
When you add a slide to your presentation, you can do the following to choose a layout for the new slide at the same time:
  1. On the Slides tab, click just below the single slide that already appears there.
  2. On the Home tab, in the Slides group, click the arrow next to New Slide.
za001093948.gif The name identifies the content that each layout is designed for. za001093949.gif Placeholders that display colored icons can contain text, but you can also click the icons to automatically insert objects, including SmartArt graphics and clip art.
  1. Click the layout that you want for your new slide.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
Aug 17, 2011 | Microsoft Office Professional 2007 Full...
Ano ang power point
PowerPoint is a presentation program developed by Microsoft. It is included in the standard Office suite along with Microsoft Word and Excel. The software allows users to create anything from basic slide shows to complex presentations.
PowerPoint is often used to create business presentations, but can also be used for educational or informal purposes. The presentations are comprised of slides, which may contain text, images, and other media, such as audio clips and movies. Sound effects and animated transitions can also be included to add extra appeal to the presentation. However, overusing sound effects and transitions will probably do more to annoy your audience than draw their attention. (Yes, we have all heard the car screeching noise enough times for one lifetime.)
Most PowerPoint presentations are created from a template, which includes a background color or image, a standard font, and a choice of several slide layouts. Changes to the template can be saved to a "master slide," which stores the main slide theme used in the presentation. When changes are made to the master slide, such as choosing a new background image, the changes are propagated to all the other slides. This keeps a uniform look among all the slides in the presentation.
When presenting a PowerPoint presentation, the presenter may choose to have the slides change at preset intervals or may decide to control the flow manually. This can be done using the mouse, keyboard, or a remote control. The flow of the presentation can be further customized by having slides load completely or one bullet at a time. For example, if the presenter has several bullet points on a page, he might have individual points appear when he clicks the mouse. This allows more interactivity with the audience and brings greater focus to each point.
PowerPoint presentations can be created and viewed using Microsoft PowerPoint. They can also be imported and exported with Apple Keynote, Apple's presentation program for the Macintosh platform. Since most people prefer not to watch presentations on a laptop, PowerPoint presentations are often displayed using a projector. Therefore, if you are preparing a PowerPoint presentation for a room full of people, just make sure you have the correct video adapter.
Jul 12, 2011 | Microsoft Computers & Internet
) What feature of Powerpoint 2010 helps in broadcasting slides to remote audience
Dear Anand,
To broadcast your presentation, do the following:
  1. On the Slide Show tab, in the Start Slide Show group, click Broadcast Slide Show.
The Broadcast Slide Show dialog box opens.
  1. Do one of the following:
    • If you want to host your slide show on the service listed under Broadcast Service, skip to the next step.
    • If you want to use some other service to host your slide show, click Change Broadcast Service. Under Choose a broadcast service, select the service that you want to use. For more information about broadcast services, see Choosing a broadcast service.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
  1. After you select your broadcast service, click Start Broadcast. PowerPoint then creates a URL for your presentation.
PowerPoint creates a unique URL for your slide show.
  1. To send the URL for your presentation to your audience, do one of the following:
    • To send the URL for your presentation by email, click Send in Email.
    • To copy the link, click Copy Link.
  2. When your audience receives the URL for the slide show, click Start Slide Show to begin your broadcast.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
  1. After you finish presenting and are ready to end the broadcast, press ESC to exit Slide Show view and then click End Broadcast.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Feb 23, 2011 | Microsoft PowerPoint 2010
Unable to exit powerpoint presentation in office 2007. suspect that powerpoint.exe may be corrupted. continues in a loop
try and press control alt and delete at same time. This should pull up a window and click on task manager and the task manager will pop up. You will then need to highlight powerpoint file and click end task. This may be your only option to exit the screen. You may also want to press escape and see if that will work at all.
Mar 10, 2009 | Microsoft Office Professional 2007 Full...
Powerpoint 2003 needed, not ppt viewer
Unfortunately, you are going to need to purchase Power Point 2003.
You can still purchase Power Point 2003 from a number of sites like
Yahoo shopping, MSN shopping etc.
Apr 09, 2008 | Microsoft Office Standard for PC
Hyperlinks in PowerPoint
it is because the compatible MS Office for windows vista is MS Office 2007. if you got a lower version, it is doesn't really work. try to get the latest version of MS Office.
Feb 26, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Office Professional 2007 Full Version for PC Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
