Question about Kenwood VR-405 Receiver
VR-405 My AM/FM is the only thing that works, my CD/DVD, Video 1, Video 2, Aux, and Tape outputs don't...
My AM/FM is the only thing that works, my CD/DVD, Video 1, Video 2, Aux, and Tape outputs don't play any sounds. The tape if turned all the way up will play a very very dim amount of my music that i have plugged into it, but its barely hearable. I get absolutely nothing out of everything else, BUT the tuner (AM/FM). I have slowly been losing one output after the other, and now i have nothing. Could this be a fuse problem? Or something else? Does anyone know where the fuses are located?
    Problem Solver:
  • 6 Answers
I buught a Mitsubishi M-VR700, which produced no audio from the speakers, but with headphones, a tiny bit of audio was detectable with the volume control on max. This solution was posted on FixYa by Mojorisin65 some time ago: Facing the receiver directly behind the MITS logo & power button is a vertical board with a large IC on it, try flexing the board near the IC while turning the reciever on & off or changing input modes, there is a cold solder joint on this board which I haven't found yet. I understand this is a common problem with the MITS M-VR700-900, Onkyo TXDS-575, & Integra DTR5 or DTR5.1 ( all made by Onkyo).
I gently flexed the board as described, and Boom, all the audio was back as it should be. I suspect Mojorisin65 is correct about the cold solder joints, but with SMT components, it could be very difficult to find. I may very well be on one or more of the 48 pins on the large IC. This IC gets rather warm during operation, which may explain why some units may work until it heats up. The chip gets warm and 'twists' enough to lift the bad pin(s) from the circuit board. In an attempt to deal with this symptom, I superglued a TO-220 heat sink to the top of the IC (don't let it touch the case of C-716). The heat sink is dissipating a fair bit of heat, and so far, this 'fix' seems to be doing the trick. RJD 10.18.11
Posted on Oct 19, 2011
  • 3 Answers
No you've probably pressed source direct or something. make sure your speakers are hooked up correctly
Posted on Jul 22, 2008
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
Oct 23, 2016 | Cars & Trucks
How do i get the bluetooth to work on an bmwx 4745
This machine has no Bluetooth:
Digital Two DIN In-Dash Widescreen/Touch Screen Monitor, AM/FM Radio, iPod Ready, DVD/CD/MP3/MP4/WMA Player, USB Port/SD Card Slot, Aux, Fully Motorized Front Panel
• Clock Display
• Electronic Audio Control
• High Power Speaker Output
• Rear Audio/Video RCA Input
• Front Aux Input (Audio/Video)
• Video RCA Output
• Front/Rear Preamp Output
• Subwoofer RCA Output
• Rear Camera Input
• Auto Antenna Control
• Auto Handbrake Control
• Full Function Remote Control
Two Din Motorized
Apr 27, 2016 | Computers & Internet
I have a VR-407 reciever and I am unable to get my CD/DVD rear outputs to work. I am hooking up a DP-3020 and I can get it to work in the Audio L/R jacks in the front. Is there something that I need to do...
A Kenwood VR-407 is a receiver and has an INPUT pair for CD/DVD, not outputs. Plug ANY functioning audio source (except a turntable) into it and select it on the front panel.
If your DP doesn't work on either I'd suspect something is wrong with IT.
May 24, 2011 | Kenwood VR-407 Receiver
The RC R0509 remote control does not respond to the receiver. I bought a universal remote and tried all the codes but still no responce.
people say that you have to tap on the receiver near the remote sensor. I don't know exactly where that is though since these are RF (radio frequency) not IR remotes, so there isn't a sensor panel in the front. I'd just tap along the front edge with the handle of a screwdriver or something. People say it works a treat.
Dec 05, 2010 | Kenwood VR-405 Receiver
Kenwood vr-405 turns on only momentarily and then shuts off
your receiver has a bad audio output ic.replacing ic will take care of the problem
Apr 10, 2010 | Kenwood VR-405 Receiver
How to hook up a kenwood audio-video surround receiver vr-405 to a 46" Bravia tv?
hello all you need is a good pair of RCA cables.
Use the audio output on the TV
run it to the VIDEO 1 input on the receiver
as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
use the receiver as a video switcher and connect your components directly to it.
remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
Hope that helps
Jan 10, 2010 | Kenwood VR-405 Receiver
Kenwood A-97 Sound gone poor
It sounds like the amplifier is going. I remember when I accidentaly crossed wires, the amp did the same thing, then one day it shut off. It wasn't the same amp, but it doesn't matter, it sounds like the amp is on its way out. :/
If you still have the warranty, I would have them take a look.
Mar 24, 2009 | Kenwood VR-405 Receiver
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
Kenwood VR-405 Receiver Logo
87 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
