Question about RCA Thomson Digital Cable Modem (DCM305R)
RCA DCM425 modem ethernet connection won't work
I was using the USB connection on computer 1 to talk to the RCA DCM425 modem. It works. When I try to use the ethernet connection it doesn't work on computer 1.
Computer 2 does connect to the modem with ethernet.
Is there some setting on computer 1 that has to be changed to allow ethernet? Then I can use the router for both computers.
  • 150 Answers
Re: RCA DCM425 modem ethernet connection won't work
In short, you have to either
  1. renew your ip on Computer 1, or
  2. hard-reboot your cable modem and then reboot or renew your ip on Computer 1.
Details below.
The modem is communicating with the servers at your ISP (Internet Service Provider) to give your computers an IP address. The ISP may have your modem set up to be issued only one IP address. Thus using both USB and Ethernet could be restricted by your ISP.
The IP address is most likely a dynamic IP that expires after a few days or weeks, unless you bought a business account that has a static IP (which is used for hosting permanent websites).
When a computer is not communicating with a Cable Modem or you shift between the connections on the modem, it may be necessary to re-establish configurations. The following can be steps to reset all components to re-establish configurations:
  1. Do a hard-reset on the modem. On the back of the modem is a reset pinhole. If you press the button quickly, this can soft-reset the modem, just restarting the modem. If you press the button and hold it for more than 10 seconds, this can hard-reset the modem, thus resetting and re-establishing configuration with the ISP servers.
  2. Restart the computer or at the command prompt (Start | Run | Cmd | Enter) issue two commands ... "ipconfig /release" and then "ipconfig /renew". This will release your IP and request a new one from your ISP.
These steps are required when adjustments occur especially when shifting between connections on the back of the modem.
Posted on Nov 26, 2007
  • 729 Answers
The setting for the Computer 1, use the network connection wizard to automatically configure the modem to work as a server station. Next, set the IP number manually and the DNS at automatic or is given by your ISP. Now the Computer 2 (workstation) should be connected to a Hub/Switch. The same, go to network connection wizard and select the appropriate connection setting, there are view samples for the connection types so explore them. After the setup, try loading your internet browser.... When done, it should work fine. Keep me posted for any problems.
0 characters
3 Points
Whenever I plug my ethernet cord into the modem and into my computer the internet still doesn't work
you might wanna check if the ethernet cord that you are using is working properly Internet light as well should be lit up on the RCA modem box.
Adriambo Tambuyat
How do I get a RCA modem to run in Ubuntu Linux? The modem works in XP, just fine.
There are no drivers to operate the modem as a USB device. Using a crossover cable (one should have come with the modem), you should be able to connect to it via the Ethernet ports on your computer and the modem.
How can I connect two ethernet cables to this modem?
If your Internet Cable Provider allows it,you will need :
1. Crossover-wired, or "null," category 5 Ethernet cable for the cable modem to be connected.
2. 10BaseT or 100BaseT Hub or Switch.
3. Straight through, or standard, category 5 Ethernet cable (one for each computer to be connected).
Be sure to check with your Internet Provider first.
Can i hook up 2 computers to the rca dcm425 without a wireless router
RCA DCM425 digital cable modems only have one Ethernet cable located in the back of the device. In order to have two computers connected at the same time you will need to have router. The router will connect to the Ethernet port on the back of the RCA modem and then you can have up to 4 computers connected directly to the router using Ethernet cables. If any of your computers are wifi compatible they will also be able to get online by using the wifi from the router.
I lost the disk for the RCA DCM425 digital cable modem the cable company gave me. how can i get the modem to work on my new computer?
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
I can't get my computer on the internet . I am using windows xp and the modem will not get the internet on the dell computer
Hi, This modem can be used via one of two ports: ethernet port (network port) or USB port If your computer has an ethernet port, it is perferable that you connect through this as you will have better performance. If you don't then you can get an ethernet card installed inside the CPU. If it's not possible to connect via this connection and you have to use the USB, then you will need drivers. This website gives you full instructions on how to use this particular modem and also gives you the USB drivers if needed. Good luck! Lolita
RCA Thomson Digital Cable Modem (DCM305R) Logo
1,261 people viewed this question
Top RCA Modems Experts
Mike McWhinney
Starnley Johnwells
Starnley Johnwells
Are you a RCA Modem Expert? Answer questions, earn points and help others
