SOURCE: black vertical lines on flat screen
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
SOURCE: Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
SOURCE: green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
