Question about NetGear WGR614 Wireless Router
Wireless doesn't work when network is secured
Have 2700 2wire router, desktop is plugged into it and everything is fine, but when the wireless connection using the wep key code no wireless internet connection can be make. Have spent many hours with internet provider and they don't know what I need to do . I'm not comfortable on an unsecured network.
Thanks
  • 51 Answers
Please check the key index set on the wireless router. Then, please check the key index setup on the laptop/desktop?
The key index can be found by going to Wireless Network Connection Properties and on the Wireless Networks tab.
Hope this helps :)
Posted on Nov 26, 2007
My new laptop doesn't work
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 12, 2012 | Samsung Computers & Internet
I am attempting to install my new Cisco linksys wireless-n-home router. I first loaded everything on my laptop and it works fine wireless. Then I attempted to load the disk on my desktop and it gives me...
You do not need the disk, if you want it on one device that is fine. log into the routers IP address and under wireless security there will be a key. If there is no key make one now. Make the security type WPA or WPA2. On the laptop, click on the wifi signals in the lower right hand corner next to the clock. Select your network and check to always connect to that network. Type the same key that was in the routers wifi security box.
In this case, the key you would type in the laptop would be what475ever. I don't even know why they shipped a CD with the things. All it does is confuse people.
Feb 26, 2011 | Computers & Internet
I have my D-Link DIR-616 C1 connected t my desktop computer. I have AT&T high speed internet and it is connected through the router. Everything works fine with the desktop. My problem is with my...
you will need to add the wireless network manually.
First you will need to remove the network from the prefered network list. I believe the Operating system on the computer is XP. and the security on the wireless network is WEP. make sure that you are typing the correct network key.
Click here for more information about routers and network
Feb 11, 2010 | D-Link DIR-615 Wireless Router
Linksys BEFW11s4 Wireless Router Security Issues
Try changing the router's channel (play around with 1, 6 and 11) and see if it works.
Jun 28, 2009 | Linksys BEFW11S4 802.11b Wireless...
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect to my router through laptops built in wireless/ps3
restart your wireless router and try again...
check the settings on your wifi router and on your desktop....
Jan 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Internect connecting
If the laptop was connecting wirelessly before and you didn't change the wireless security key on the router during your troubleshooting steps with the ISP then it should just reconnect. If it doesn't reconnect you should probably delete the wireless profile that's saved and try connecting again. When you delete the wireless profile you will have to enter the security key again. Make sure you have this information handy.
If you are uncertain what the wireless security key is use your desktop that is physically connected to the router to log into the router and reset the security key.
To log onto the router you need to know the routers IP Address. You can obtain that information through the following:
START MENU
RUN
Type CMD
Click OK
Type IPCONFIG
Hit Enter
Look for the default gateway. The default gateway is the IP Address of the router. By default the IP is 192.168.1.1.
Type whatever IP Address you discovered into the address bar of your web browser (Internet Explorer for most) and hit enter.
You will be prompted for a login. If you didn't change the default login information to the router it should be a blank username and the word: admin - as the password.
Navigate to the wireless settings and reset the security key.
From your laptop key in the new network key.
Hope this helps.
MO
Jul 18, 2008 | Linksys Wireless-G WRT54GS Router...
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
NetGear WGR614 Wireless Router Logo
138 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
