SOURCE: passcode
You might have bought a stolen one. I was installing a sub in my car and unplugged mine and it required a pass code, which i forgot for a while, but luckily remembered. I called about getting it reset and they said I had to bring it in to a official Kenwood ceter in order to get it reset. I would just suggest to call Kenwood. Also, i'm currently looking for a new one because mine was stolen again, so hopefully the person who stole it is having a problem installing it in there car. good luck.
SOURCE: How to fix a broken 20GB 360 hard drive?
the only way to fix it is to ring microsoft explain it to them then they will give you a code to format the hard drive and start over hope this helped u
SOURCE: How to tell if my laptop is wifi ready
In your operating system go to control panel and follow the prompts of the network setup wizard ( select wireless setup) and follow the steps of the wizard. But you better have a wireless network type card in your laptop.. Usually there is a little switch on the unit soemwhere that displays an orange or blue light that is the network card.
SOURCE: Can't upload to my laptop!
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Your Camcorder does not supports a Wireless MIC. However, you can use a MIC with your Camcorder using the available Accessories Shoe port.
Good Luck!!!!!!!!!!!!!!!
SOURCE: Trying to drop my ebay sellers account. The
1. Go here: http://cgi1.ebay.com/ws/eBayISAPI.dll?CloseAccount
2. Login if it asks you
3. Select the reason
4. Confirm closure of your account
