Question about Sony Handycam CCD-TRV108 Camcorder
Sony handycam video hi8
Everytime i turn on the camera it says re-attach the power source and it wont record or playback it has full power i even bought a new battery and fully charged it it still flashes the same message re-attach power source even though it is fully powered what is wrong??????????????
  • 4,402 Answers
Re: sony handycam video hi8
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
0 characters
3 Points
I have Sony camera recorder CCD-TRV228E PAl Hi8.....
t is working OK,but i cant see anything on the display...
Somebody told me it was something like ICT orr TCI4 chip....
Can anybody tell me something about this probllem..??
Dec 02, 2010 | Sony CCD-TRV228E Camcorder
I can't play a hi8 cassette recorded in another camera y my camera, what can i do?
DCR-TRV130 is not capable of playing back 8mm or Hi8 tapes recorded on analog camcorders. Digital recording playback only.
Feb 16, 2010 | Sony Handycam DCR-TRV130 Digital Camcorder
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
Sony handycam will not record
dirty video head. go to a store and buy a video head cleaner. that should take care of your problem. yes, even if its new the heads can get dirty just from dust or moisture.
Mar 26, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
I also have a SONY 460x Handycam Vision CCD-TRV68 NTSC video Hi8 Steady Shot not able to record a picture but will record audio, playback is the same. Unfortunatly this occured after warranty was out. Seems like this might have been a manufactors defect.
Sep 24, 2008 | Sony 2.0MP Handycam High-Definition DVD...
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Playback static
Your video heads are probably dirty. I have the same problem with mine too. If you buy a 8mm video cassette cleaner, it should work. Unless there is some other problem.
Jul 11, 2008 | Sony Handycam CCD-TRV318 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Feb 17, 2007 | Sony Handycam DCR-TRV255 Digital Camcorder
Sony Handycam CCD-TRV108 Camcorder Logo
207 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
