Question about Canon PowerShot A85 Digital Camera
Canon a85 only works with no Memory Card.
I have had that a85 for less than a year, and went to use it, and it would not turn on. I knew the batteries were charged, but went ahead and put new ones in. Nothing. So I took the memory card out to put another one in. Still nothing. So took the memory card out and turned it on. Bam, camera works, only with no memory card. While trying to figure this out, the camera came on twice with a memory card in, and said memory card error. All the cards were formated correctly. Im lost here and, need a digicam, any help is well appericated.
  • Canon Master
  • 4,738 Answers
Re: Canon a85 only works with no Memory Card.
Here are some simple things to try first for a camera that won't power on. Recommend trying the first step listed for the A520:
Posted on Dec 08, 2007
0 characters
3 Points
I cannot get a image to show up on the camera when I turn the camera on.
If your Canon A85 camera shows memory card picture in playback but does not show live image in camera mode then it is ccd imager chip failure problem and ccd imager chip will be replaced.
Canon offers free of cost ccd imager chip replacement for A85
Click Canon CCD Imager Advisory for details.
Feb 05, 2010 | Canon PowerShot A85 Digital Camera
What is the highest memory card for Canon Powershot A85 will support? 512MB, 1G to 4G ?
Memory cards are storage devices, so there is no highest storage cards. Your choice of storage cards depend on how large you want your file to be before uploading. So you can use up to 4G or more memory card for your Canon Powershot A85
Dec 27, 2009 | Canon PowerShot A85 Digital Camera
Will not turn on have replaced batteries
Things to check first are battery contact points, and micro switches that are located on the battery and memory card doors. Details on what needs to be checked may be seen here. It won't work for every case, but it's worth a try.
Oct 30, 2009 | Canon PowerShot A85 Digital Camera
What size in inches is a A85 memory card. I put
The A85 uses a Type 1 Compact Flash (CF) card. If you're trying to put an SD card into the slot, it won't work. Using a strong light, check carefully in the card slot that you haven't bent any pins before inserting a CF card.
Aug 26, 2009 | Canon PowerShot A85 Digital Camera
No picture in lcd when camera is in camera mode
If it is Canon A85 camera then it has known problem of CCD Imager and this part will be replaced.
Canon will repair free of cost A85 in CCD Imager problem as per announced scheme.
Please click Canon CCD Image Sensor Advisory for details.
Feb 06, 2009 | Canon PowerShot A85 Digital Camera
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
A85 won't turn on..
go to one of the suggestions on there said to tap the usb port entry point on the desk, well we banged it rather than tapped it but it works fine now, thank you and good luck
Nov 03, 2007 | Canon PowerShot A85 Digital Camera
Canon A85 has stopped shooting
The A85 has had problems with the operations deck assy which contains the primary controls that the customer uses to operate the camera. If this is the problem, the part is approx. $60 from Canon, I am not sure what they charge for labor to replace the bad component. Good Luck to you. Joe Weibel
Feb 11, 2007 | Canon PowerShot A85 Digital Camera
100 expensive pictures
it seems the ur switch (the one on which u select camera or memory card) is faulty
Dec 03, 2006 | Canon PowerShot A85 Digital Camera
LCD Screen = Kaput?
It's a wild guess, but I have a visual image of the shutter mechanism getting stuck during the rapid release thing. I heard it can sometimes be fixed by tapping gently on the lens area. Whatever comes to mind has to do with the camera being over taxed during that shooting session, and something got jammed or blown. Hard to find someone qualified that will work on digital cameras for less than the fortune the manufacturers ask for, but it won't hurt to look. You could call Canon and tell them what happened, say that it's hardly over a year and that it's likely a design flaw with the rapid-picture thing. maybe you'll get lucky... ;=] When you changed batteries, how long was the camera battery-less? If not long try resting it sans battery for a good few hours, maybe it will come back from the dead. Hope you find a way, let us know
Jun 05, 2006 | Canon PowerShot A75 Digital Camera
Canon PowerShot A85 Digital Camera Logo
74 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
