SOURCE: Where did my gmail account go? I also set up a
Hi
Most often it is a font or upper case, lower case, or symbol issue,
either with your log-in name or password, or both.
When you said up the accounts, you should have recieved a confirmation notice in your email of account set-up.
When you get to the long in screen, copy and paste your log-in information directly from your confirmation/account information that they sent you.
Should this not work, if u submit to them your log-in user name ,they will provide your password.
Again copy and paste the information in, so it reads exactly how they have it showing.
Good luck.
SOURCE: gmail account claims wrong user id or password
Why would Gmail claims that just for you?
All the above are real possibilities. Try again carefully. If you use Firefox you may be able to recover your password. Here is a screen capture to access the passwords. The screen language is French but that should not be a problem: Look at the icons. Click the button under the second Exception button.
SOURCE: Repected Sir/Madam My gmail id is
Issue: Unable to access Gmail Account even after having the correctUser name and Password
Note: Dear sir, please do not disclose any of your personal password online. That would cost you heavier at times in cases of credit cards or even mail account IDs like these.
Solution:
http://mail.google.com/support/bin/answer.py?hl=en&answer=46346
Please open the above link and follow the steps provided. This should definitely help you in gaining access to your Account login.
Please revert me back if you require any further assistance with this issue.
SOURCE: my sanyo zio with cricket
Everyone says to do a hard reset, DONT. All you need to do is put your Google email in the user name box then put the word "null" in the password box. Once that is done it will ask you to to make a new pattern and then everything is back up and running. I went right in turned off the pattern lock, I never want to see it again. Also it might take a few trys to put the user name and password in. The second try worked for me.
SOURCE: 2 gmail accounts one is not working, plz help
ive had a phone that had a gmail on it and now i can get in it ple help
