Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Jennair range oven goes off and then comes on and continues to do that the oven flashes f5 the top works Pushing BAKE Pad, BROIL PAD, CONVEC BAKE, CONVEC Roast produces an Off error message. Oven will not come on.
  • 1,113 Answers
Re: jennair range
And they say the customer is always right LOL
Posted on Nov 30, 2007
  • 213 Answers
Re: jennair range
F-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Posted on Nov 26, 2007
0 characters
3 Points
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 20, 2012 | GE Stove / Oven / RanMain Glass Top Assy....
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Jennair gas range model jgr8850adw, has an error code of f1 during oven cleaning cycle, help?
Oct 30, 2009 | Jenn-Air...
How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Feb 08, 2009 | Maytag MGS5770 Gas Kitchen Range
Hello sfgelectric,
You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
Does the display flash any error codes, or just the bake light?
Fault codes
1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
3.Wait a few minutes, and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized servicer.
4.If the oven is heavily soiled, excessive flareups may result in a fault code during
cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
excess soil, then reset
For most concerns, try these first.
Check if oven controls have been properly set.
Check to be sure plug is securely inserted into receptacle.
Check or re-set circuit breaker. Check or replace fuse.
Check power supply
I'll check the repair manual to see what I can find.
Let me know how it goes.
Perhaps this will fix a glitch.
Remember to leave a rating.
Oct 16, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Jennair range
f-5 means the oven control is bad. you need to replace the oven control/clock. only way to fix the problem
Nov 22, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Jun 08, 2006 | Maytag MER5530 Electric Kitchen Range
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
192 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
