Question about Nikon Coolpix 5000 Digital Camera
Blank Monitor with Light
I have a Nikon Coolpix 5000, all of a sudden my monitor will not display anything. There is a light on the screen but that is it. I can not review any pictures either. Please help. I have looked everywhere in my manual.
  • John Oak Apr 09, 2008
    Got the same problem: a white display (backlight is working) no display of images (preview nor of stored images). Has happened before but went away again. Now it seems permament. Changing and/or charging battery does not help.
Same thing has happened to me.
Posted on May 24, 2008
Nikon Coolpix S9400 - the monitor has gone blank, although camera is not "dead".
The Display is OLED and when it is off it is really OFF.
FYI:
This camera has FIVE (5) Brightness levels for the display. The Brightness is usually set in the TOOL (wrench) menu.
If you are positive the batteries are good, fresh and or fully charged it is MY OPINION that the camera is non functional. The Viewfinder is critical for camera operation. Sorry I am not much help here it seems this camera needs either repair or replacement.
Dec 03, 2016 | Nikon Coolpix S9400
Display monitor on my Nikon coolpix s4 is not
I am having this problem also. I have reviewed the manual from back to front and cannot find the answer to my problem.
Jul 15, 2010 | Nikon Coolpix S4 Digital Camera
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Nikon coolpix 4300 monitor lights up and displays
It is time to replace that camera. If the sensor is bad it will not take pictures, if the play back does not work it will take picture but no show. If you camera wont do either than it is too far gone for repair and should be replaced.
Nov 19, 2009 | Nikon Coolpix 4300 Digital Camera
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Black monitor Nikon Coolpix S4 Digital
    Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
    good luck.
    Jun 21, 2008 | Nikon Coolpix S4 Digital Camera
    No image on the scree
    If you can play back images and they can be seen on the LCD monitor, then the problem is the CCD sensor ( see image below to get an idea what I am talking about ).Nikon fixes this problem  free of charge so that is good news for you. But if there is no image in playback mode then it might be the LCD monitor.Unfortunately this will not be repaired free of charge if your camera is out of warranty.ba67e42.jpg
    Oct 22, 2007 | Nikon Coolpix 5000 Digital Camera
    Blank Screen
    Can you see anything at on but dimly? If so thats is the backlight tube If you cannot see anything then it is a major fault eitherway a repair shop job I should think
    May 30, 2007 | HP L1902 19" LCD Monitor
    Mostly blank screens with moving streaks of light
    This is a known problem in the Coolpix 5700 - Nikon will replace the defective CCD at no charge. Go here: http://www.imaging-resource.com/badccds.html
    Nov 22, 2006 | Nikon Coolpix 5700 Digital Camera
    Nikon Coolpix 5700 - Blank Viewfinder/Monitor
    This is a known problem with the CCD - Nikon will replace at no charge. Go here: http://www.imaging-resource.com/badccds.html
    Nov 21, 2006 | Nikon Coolpix 5700 Digital Camera
    Nikon Coolpix 5000 Digital Camera Logo
    216 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
