SOURCE: Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
SOURCE: uniden 5.8 ghz phone. Can you turn the ringers off and how ?
On most of the phones you just keep pushing the volume down button untill it turns off. On some models there is a "Do not disturb" feature, usually it is a soft key feature so look on the LCD screen. Also, for the person that can't turn the ringer back on, just push the volume up key untill the ringer is at the level you like.
SOURCE: I need a manual for a Binatone Big Button 600 -
Select the manual from the drop down list on page below to start download:
http://www.binatoneonline.com/manual.asp...
SOURCE: BINATONE CORDLESS PHONE MA 760
you have to press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button scroll to OGM REC. record ya message after the tone then press ok when done. then scroll down the menus again (press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button) scroll to TAM ON, press ok and thats the answering machine.
