e
emmerentia welthagen Posted on Oct 18, 2018
I want to down grade but still be able to record and use catch up. what packages are available
Harry Reinhardt
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Oct 18, 2018
Harry Reinhardt
Contributor
Level 1:
New Friend:
Answers
9
Questions
Helped
4167
Points
24
Tell them you want to cancel your subscription as you can afford it anymore, you may have to talk to several people before they offer you a better package and cheaper. If all else fails just rejoin as a new customer with all the latest feats.....
Denon Avr 2112 how to fix problem shutting down
http://www.mamondelashes.com/customized-packaging-3d-eyelashes/customized packaging 3d eyelashes Customized packaging 3d eyelashes-Mamonde Lashes Wholesale price customized packaging 3d eyelashes.Our customized packaging 3d eyelashes is very soft and natural.And we can help you produce customized logo or package box If you need. And our is the top selling manufacture,so our lashes quality is best and service is thoughtful and fast delivery.
1helpful
We have been DSTV clients for many years my husband went on pension and we can not afford the full package anylonger we want to down grade to a cheaper package
not a question for this page
It is an agreement between you and the supplier and any inquiries and possible changes must be made to them either by phone direct or in writing
Good sound card to record speeches
All sound cards can record either through the microphone input or line input (in sterio) A sound recording/editing package like Audacity works very well - free downloads available.
2answers
How to install package manager in ubuntu?
A package manager is a program that installs and uninstalls software, and keeps track of all the components each piece of software needs.
Dpkg is the Ubuntu package manager dpkg is a medium-level tool to install, build, remove and manage Ubuntu packages. The primary and more user-friendly front-end for dpkg is dselect.dpkg itself is controlled entirely via command line parameters,which consist of exactly one action and zero or more options. The action-parameter tells dpkg what to do and options control the behavior of the action in some way.
Now we will see all the available commands for dpkg with examples
1) Install a package
Syntax
dpkg -i <.deb file name>
Example
dpkg -i avg71flm_r28-1_i386.deb
2) Install all packages recursively from a directory
Syntax
dpkg -R
Example
dpkg -R /usr/local/src
3) Unpack the package, but don’t configure it.
Syntax
dpkg --unpack package_file
If you use -R option is specified, package_file must refer to a directory instead.
Example
dpkg --unpack avg71flm_r28-1_i386.deb
4) Reconfigure an unpacked package
Syntax
dpkg --configure package
If -a is given instead of package, all unpacked but uncon-figured packages are configured.
Example
dpkg --configure avg71flm_r28-1_i386.deb
5) Remove an installed package except configuration files
Syntax
dpkg -r
Example
dpkg -r avg71flm_r28-1_i386.deb
6) Remove an installed package including configuration files
Syntax
dpkg -P
If you use -a is given instead of a package name, then all packages unpacked, but marked to be removed or purged in file /var/lib/dpkg/status, are removed or purged, respectively.
Example
dpkg -P avg71flm
7) Replace available packages info
Syntax
dpkg --update-avail <Packages-file>
With this option old information is replaced with the information in the Packages-file.
icon_cool.gif Merge with info from file
Syntax
dpkg --merge-avail <Packages-file>
With this option old informa-tion is combined with information from Packages-file.
The Packages-file distributed with Debian is simply named Packages.dpkg keeps its record of available packages in /var/lib/dpkg/available.
9) Update dpkg and dselect’s idea of which packages are available with information from the package pack-age_file.
Syntax
dpkg -A package_file
10) Forget about uninstalled unavailable packages.
Syntax
dpkg --forget-old-unavail
11) Erase the existing information about what packages are available.
Syntax
dpkg --clear-avail
12) Searches for packages that have been installed only partially on your system.
Syntax
dpkg -C
13) Compare Package versions version numbers
Syntax
dpkg --compare-versions ver1 op ver2
14) Display a brief help message.
Syntax
dpkg --help
15) Display dpkg licence.
Syntax
dpkg --licence (or) dpkg --license
16) Display dpkg version information.
Syntax
dpkg --version
17) Build a deb package.
Syntax
dpkg -b directory [filename]
18) List contents of a deb package.
Syntax
dpkg -c filename
19) Show information about a package.
Syntax
dpkg -I filename [control-file]
20) List packages matching given pattern.
Syntax
dpkg -l package-name-pattern
Example
dpkg -l vim
21) List all installed packages, along with package version and short description
Syntax
dpkg -l
22) Report status of specified package.
Syntax
dpkg -s package-name
Example
dpkg -s ssh
23) List files installed to your system from package.
Syntax
dpkg -L package-Name
Example
dpkg -L nagios2
24) Search for a filename from installed packages.
Syntax
dpkg -S filename-search-pattern
Example
dpkg -S /sbin/ifconfig
25) Display details about package
Syntax
dpkg -p package-name
Example
dpkg -p nagios2
Please check if this is any help for you.
Regards.
I cant seem to record more then one song
When you create a new song you switch to the new song automatically. To get back to the old one you just have to 'load' it from the list of available songs. As long as you shut down properly the song you are working on is automatically saved. It will automatically load again until you either create a new song or load another stored song.
bd.
1helpful
Torque specs
Type: Bolt Dim: Length: Head: Hexagon Grade: 17 Ft-Lbs 204 In-Lbs 23.05 N-m Connects: Crankshaft To Connecting Rod Years: All Vote Record: Vote Note: FS - Rod Cap Bolts - 2 Step: 17FtLbs; +90deg Type: Bolt Dim: Length: Head: Hexagon Grade: 15 Ft-Lbs 180 In-Lbs 20.34 N-m Connects: Crankshaft To Engine Block Years: All Vote Record: Vote Note: FS - Main Bearing Cap Bolts - 2 Step: 15FtLbs; +90deg Type: Bolt Dim: Length: Head: Hexagon Grade: 72 Ft-Lbs 864 In-Lbs 97.62 N-m Connects: Crankshaft To Flywheel Years: All Vote Record: Vote Note: FS - Flywheel/Driveplate Bolts Type: Bolt Dim: Length: Head: Hexagon Grade: 120 Ft-Lbs 1440 In-Lbs 162.7 N-m Connects: Crankshaft To Pulley Years: All Vote Record: Vote Note: FS - Crankshaft Pulley Bolt
2answers
CDR200
Push CD Sync...when goes into it....push record or pause....like a double tape deck.
Top Able Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an Able Audio Player and Recorder Expert? Answer questions, earn points and help others
