I think you printer has (Error code 0x000003eb)
Error code 0x000003eb is a printer link installation error. If you are trying to build a printer, but can not do so because of the error code 0x000003eb, then you are in the right place because we are going to explore today how to fix this issue. The error message does not provide you with any detail as it just reveals that the printer can not be installed and that 0x000003eb is an error code.
The printer connectivity or printer installation error is seen to be the Error Code 0x000003eb. Installing a printer driver, but retaining error 0x000003eb prompts, make sure that you log in as the device administrator and then begin to load the driver.
Your issue also exists even though your old printers are deleted and replaced and all print ports are deleted. But the printer can be properly added and run properly when the printer is linked to the device via USB cable, or connected directly via IP address.
Please my epson stylus 1410 is end of service life, I wanna fix it myself please guide me
SOURCE: Epson stylus D88 - blinking red lights
this means that your printer need to be reset this should work http://www.ssclg.com/epsone.shtml
SOURCE: blinking red lights
I have a canon s630 and the yellow light blinks 7 times and green once, what is causing this and can i reset this printer?
SOURCE: power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
SOURCE: green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
SOURCE: Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
