SOURCE: 1998 chevy s10 won't start, engine cranks but it won't turn over.
replaced your fuel pump and when you buy it make sure to replace the oil sending sensor on the fuel pump it comes with a replacement when you purchase a new fuel pump
SOURCE: 46" mtd 25hp riding mower. Idoling ruff...
I had a similar problem on my 42" MTD riding mower, the vent in the gas cap was plugged up. Replaced the gas tank cap and it fixed it (Lowes sells them)
SOURCE: Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
