PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Black screen will not boot up
By muffs on Nov 26, 2007
HP PAVILION DV2000 will not boot up. When i press the power button all lights come on but laptop will not boot up.
Clarification Request
Posted by phoenixtron on Dec 03, 2009
Ok, first off i have a dell Inspiron 1420 i was playing a game called Lunia then i leave for a mere 3 minutes to get a soda. Once i return i notice that the screen was black. Thinking that it simply turned off the monitor or went to sleep i moved the cursor around and still black so i presumed it was in sleep mode, so i as lazy as i am manually shut it off in less than 7 seconds. Giving it time to completely shut off i wait 10 seconds then i attempt to turn it on. But to my surprise it stayed black i mean it looked like it was turning on normally like how it should but it didn't it just stayed as a black screen. Thing is though that i didn't need to hold the power button as it normally does. But just a mere press in the button turns it off while it is in black mode. Again i do the same thing in turning it on and again it stayed all black not showing anything at all i can't even see when i press f12 or f2 it's just a black screen and so cannot even see the welcome screen. So what can i do to fix this?
Same Problem
Apr 16, 2009
-   i have also chose the option to run starup repair when it comes up and did a system restore but still no luck. safe mode loads up fine but keyboard and touchpad are inoperable. i have also tried to run a memory test and it got all the way to like 95% and failed and restarted the computer. If anyone can lend any help to these problem it would be thankful. -   b_randon14
Apr 16, 2009
-   i have an acer 4730z and i went to boot it up one day and it came up to a black screen after showing the vista loading page. I have restarted in safe mode but my keyboard of touch pad neither work. i have vista home 32 with 3gb of mem. Wondering if anyone else has had similiar problem...much thanks -   b_randon14
Dec 27, 2008
-   I have the same problem on an HP Pavilion dv2000 laptop. Leds light up but nothing else. Tired reseating the memory and the hard drive. No improvment. Also tried connecting an additional monitor. No improvement. -   Guest
Dec 19, 2008
-   it is not working
-   Guest
Jul 17, 2008
-   Hi, I have the same problem, I just got my HP DV2700t special edition laptop, I set it up and it worked fine for a few hours and then it stopped responding. I used the power button to switch it off and when i tried to switch it back on, all the led would glow, the power inlet was blue indicating power supply. but the screen is black. there is absolutely no activity. i took the battery out, plugged out the ac adapter, and put them back in, but nothing happened. I reseated the memory cards, and still no change. I do not know what else to do. I guess I'll just get an exchange laptop. -   Guest
Best Solution
posted on Jan 31, 2008
Helpful)
stuboy
Rank: Apprentice
Rating: 91%, 5 votes
hi. on the dv2000.....i have the same issue...all lights turn on but no activity or life on the screen from the laptop....can anyone help me urgently please? tried reseating the ram etc etc..no avail.
Was this helpful?
Yes
No
Solution #2
posted on Nov 26, 2007
Helpful)
Poohawk
Rank: Wiz
Rating: 84%, 255 votes
Try reseating the memory modules and powering back up. This is a common problem and a common fix. If that doesn't do it, try reseating the hard drive. If that doesn't work, get back to me with more details and we'll go from there.
Thanks!
Ron-
Was this helpful?
Yes
No
Solution #3
posted on Apr 19, 2009
Somewhat Helpful)
bergiekat
Rank: Apprentice
Rating: 75%, 1 votes
ok, hubby had this problem on his Compaq...black screen...seemed to be doing something as the cd drive would spin, all lights came on, but black screen. Don't know how long this will work, but try pressing the frame above the F6 key when you boot up. (I know it sounds weird, but work with me!)
There is something about this being where the video card attaches to the mother board and no clue how long it will continue to solve the problem. It will give you enough time to at least retrieve data you need off of your hard drive and burn to cd(s). I think the video card is integrated into the motherboard, thus once it dies completely, you'll still have all of your data backed up as it will be as expensive to replace the motherboard as it will to buy a new laptop!
Good luck! (We are furiously backing up data as I type!!!!)
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
i have a hp pavilion 2000 the keyboard and mouse arent working i reinstalled the driver that somes... (More)
Answer
I have a Dell Inspiron 1300 with an internal DVD-Rewriteable drive. I'm trying to write a DVD-R disk... (More)
Answer
sirs i have an acer 3050 sadly got droped. screen shattered.have had replaced. but now all i get is... (More)
11 Other Users Have The Same Problem - Continued
Comment by gmoney9842, posted on Jul 08, 2008
i have the same problem i have a hp pavilion dv2000 it turn on but the screen is all black screen it stay there then a sec i turn on but on then it show to log in windows vista
Comment by punchynella, posted on Apr 17, 2008
I have the same problem. However, I hooked my laptop to my nephew's desktop monitor and realized that even though I didn't see anything happening there was still life in the computer. Try it and see if you can see anything using another monitor. turn off the laptop and unplug the adapter from the laptop, hook the monitor up (must be off and unplugged before hooking it to your laptop, once everyting is hooked up turn on the monitor and boot up your laptop and see if you can access your laptop and fix the problem.
Comment by Adkins1984, posted on Mar 04, 2008
My computer powers on with all lights (including the charge light, and hard drive activity light), but that is all. I tried removing the CMOS Battery and that didn't do a single thing. Just to be on the safe side I left the battery out all night so I was sure the BIOS would be reset. I am not sure how to reset the ram or the hard drive so a little guidance on that would be great.
Comment by Tillion, posted on Jan 02, 2008
I turn my lap top on and every light turns on besides the charge one and I belive the hard drive activety one and my screen is just black.
Comment by DJ Azzuro, posted on Dec 23, 2007
The laptop froze during play..The sound stuck like a broken record except in one place like it was jammed.. We had to take out the battery to turn it off. We now see the HP logo then nothing.. If u hit a key it flashes and says, operating system not found.
Comment by kalvin, posted on Dec 05, 2007
Hi, I seem to be having the same problem. I reseated the RAM dimms and the hard drive and doesn't work. I've also tried resetting the bios by disconnecting the little battery for a few minutes.
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , MD
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
