SOURCE: which toner do I use for sharp AR-M420U/Mx 2300g
AR-450ET
Testimonial: "I found this fixyah from a friend and I glad you are doing a nice job. I was very messed up with toner type type nobody new it the type. Thanks again"
SOURCE: my AR-M420U sharp printer/copier displays (call 4
problem is in the crum. re insert the cart. into developing.
SOURCE: after installation my sharp ar-m420u
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
SOURCE: Im need softwaer driner for
Go to www.sharpusa.com. Then customer support, then printers and MFP's. You should be able to find print drivers to download there. Good luck.
