Question about In Office Equipment & Supplies
I only have black ink in my printer - can I print a coloured item only in black - how do I do this ?
  • paula palmer
    paula palmer Oct 10, 2019
    yes, you can printer coloured item in black. But the printout will come in black form only.
    Master:
  • In Master
  • 459 Answers
1) Well, the basic law in printing is to get black print output from the black ink cartridge.
2) Expecting or planning on printing a colored item from a black ink cartridge is not possible. Use a color cartridge to print color printouts.
3) Respect the laws of nature.
Posted on Nov 27, 2018
    Dedicated:
    Visited the website for 20 consecutive days.
  • 439 Answers
You should have an option either on the printer driver program or as a setting on the printer itself for colour/ black and white printing.
Posted on Oct 17, 2018
SOURCE:
jyvibar
  • 148 Answers
SOURCE: sharp AJ1800 printer - won't print colour
the color cartrige is defective. replace only with original cartriges
Posted on Mar 23, 2008
Silverblade
  • 173 Answers
SOURCE: Black ink not printing and colour ink very faded
Check the ink status of the printer's cartridge.
Posted on Oct 14, 2008
worldvet
  • 859 Answers
SOURCE: epson stylus DX 7450 doesn't print black
Hello, This can be FIXED. I'm not trying to be helpful. I'm here to FIX your problem.
You want to make changes to the printer settings to once again print in Black and White or Grayscale mode by going to Start Menu, Control Panel, Printers. Right click your printer and select Properties. Now make the changes to everything prints Black and White or Grayscale. This will make the change effective system wide as opposed to what you did which was for a single print job in a program.
Now, unfortunately, you will still get an error message that your color cartridges are empty anyway because they are.
To disable the error message do this.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
This will disable the empty cartridge error on most Epson printers.
Let me know of your results as I am here to FIX your problem. I'm not here to be helpful. I will work with you until this is FIXED or is now FIXED. OK? Use the comment box below to let me know your results.
Regards,
Worldvet
Posted on Nov 09, 2008
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
SOURCE: Using colour ink without black ink in Epson CX5500
this cannot be resolved, Epson software is useless it will force you to buy an INK
Posted on Jul 13, 2009
Quicken 2008 won't print anything in reports in black
You need to replace the Black cartridge, as it appears the colour one is fine. Look in the printer options on your PC for a display of ink levels, and you'll probably find the black down to zero. If you've used generic cartridges, not genuine HP, you may find the printer can't actually read the ink levels.
Feb 06, 2013 | HP Photosmart D7260 Printer
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
The printer in out of colour ink, and still wont print in black and white
Replace the colour ink. Some printers mix-in a bit of coloured ink, when printing "black", in order to prevent the colour-inks from drying-out.
Feb 17, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Lines in photo
Hi
This could be either a leak from colour cartridge or could be because there is still some blue ink in the printer from the last colour item printed?
Apr 10, 2010 | HP PhotoSmart C4280 Laser Printer
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Epson sx200 One of the colour inks is empty and no print in black
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
44 people viewed this question
Top In Office Equipment & Supplies Experts
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
