The data sheet lists 9097250 as sone type of identifier... as well as 56c07472
SOURCE: transistors
Are the transistors missing?
You're unlikely to find a schematic for it. Since the amp is likely a clone, you may be able to use a schematic from another manufacturer to troubleshoot it. If you can send me a clear photo of the power supply components around the TL494, I may be able to help.
[email protected]
SOURCE: Lost Instruction sheet
Open your watch and find movement number. This must be pressed on movements plate. Upload full number here and I'll guide you further.
SOURCE: 1992 Rockford Fosgate Power 100HD transistors
they are gone gone long gone there is no information about it
i remember 15 years ago having the same problem with the 100 hd and the 75 hd
call fosgate they fax me the schematic showing the modification
how to use different transistors and a new resistor have to be replace for each transistor
good luck
save that amplifier i have mine in the close-tt
SOURCE: a transistor or resistor burnt
You have not mentioned what electronic equipment you are requesting the details.
You will be able to confirm the transistor value from the stage where it has burned which also goes for the resistor. So take tech help than to try with trials to damage the set much further.
