Question about Canon PowerShot A85 Digital Camera
Cannon A85 E18 code occurring
Hello there, my camera, when switched on comes up with a E18 signal in the corner and that is all i can get to come up on the screen at the moment, i hope u can help me, cheers, Merridie
    Novelist:
  • 150 Answers
Unfortunately, this error has only three fixes. Based on your purchase date and expertise.
  1. Return it for a refund/exchange.
  2. or, send it to be repaired by Canon or your local service center.
  3. Repair it yourself following these instructions.
This link is where you can get more details.
If this has helped, please rate it a FixYa!
Posted on Nov 26, 2007
SOURCE:
PROBLEM WITH - Cannon PowerShot A85:- The
switch off the camera and take out the baterys for a muinnuit then put nthem back in then switch on the camera if you still have the same problem you may need to use the same type of batterys as wos with the camera
Mar 07, 2011 | Canon PowerShot A520 Digital Camera
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
Cannon Powershot S21S is stuck on on/ A message E18 came up on the blank screen in the let hand corner. changed the batteries plus the lithium battery.
Thank you !!
Jun 30, 2010 | Canon PowerShot S2 IS Digital Camera
E18 screen msg
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
The screen won't come on for viewing and the lens won't retrack, it also started popping up with E18
That is shutter error code. I am sorry to tell you have to buy a new camera, it would be to expensive to replace.
Nov 15, 2009 | Canon PowerShot A95 Digital Camera
E18 appears in lower left part of screen when camera is turned on
The E18 error is fairly common on certain Canon models. Here's a link to information on what usually causes it and how to fix it. http://www.e18error.com/
Apr 04, 2009 | Canon PowerShot A85 Digital Camera
I have a powershot A85. Lens wont retract. Camera cuts off after about 10 seconds. Bottom left corner reads e18 just before it turns off.
this is a popular error due to dust or sand in lens assembly
search google for e18 solutions will flood
Oct 21, 2008 | Cameras
Canon e18 error
error code e18 means that the focus motor gears a jammed, dirt or grain of sand in them. you can try to fix it by gently banging the camera on somthing soft, their are also instructions on web on how to disasemble and fix this fault. BUT unless you have some skills, the right tools and conditions i would not attempt it. leave it to the experts. their are several flat cables, without actually seeing I cant tell you
Aug 30, 2007 | Canon PowerShot A85 Digital Camera
Canon PowerShot A85 Digital Camera Logo
1,049 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
