Check ignitor on bottom
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
SOURCE: Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
The ignitor is not working right and is going bad....
have
the repair man replace the ignitor, or DIY....
Check out this tip
about your problem...
Oven not Working or Oven
not Heating
Oven
Problems Replacing the Igniter
heatman101
