I think you are referring to internal memory and not memory card. that can only be replaced at a service station.
If your mean memory card then you must first disable it in software (press power button lightly n see if any option comes like remove memory card) and then remove from the card slot.
You don't need to remove the internal memory. Simply insert the memory stick, and the camera will store new images and videos to the stick instead of the internal memory.
You can copy all the images from the Internal Memory to a Memory Stick Duo media using the COPY option in the Memory Stick Tool Menu option.
Please insert the Memory Stick Duo media with sufficient free capacity into the Camera.
Select MENU--> Settings-->MemoryStickTool-->COPY-->OK.
The original images in the Internal memory retain after copying. You may have to delete the contents of the internal Memory. Remove the Memory Stick media after copying, then format the internal memory. FORMAT in Internal Memory Tool.
You can only copy the images to the new folder created on the Memory Stick Duo which is created automatically. You cannot copy the images to a specific folder.
Remove the memory card from the camera, go into menu and locate format, follow the prompt to remove all pictures from the internal memory, when completed install the memory card for normal operation.
Take out memory card from camera, format internal memory to delete all pictures at once or delete them one by one. Once memory card is inserted in camera, internal memory is no longer available to store/ delete pictures so remove memory card from camera to get access to internal memory.
When you remove the card, can you review the pictures that are on the internal memory? If you can and you want to save them, download them to your computer. Then, with the memory card still out of the camera, format the internal memory.
remove the memory card and you should be able to see the images stored on the internal memory by pressing the playback "arrow" button. If it says no image found, there is nothing currently on the internal memory. With a memory card inserted, the camera defaults to the card only, and ignores the internal memory.
internal memory is located inside your laptop. u need 2 open it from behind. but it is very risky for you to open it yourself you might damage some parts on your laptop.
