VHS has audio but no video
My Sylvania DVR90VF DVD VHS Combo all of a sudden has no video when playing VHS tapes. The audio works. Worked fine last time it was used. DVD's play fine.
  • 5 more comments
  • emofarm Nov 26, 2007
    I get VHS video only when dubbing from VHS to DVD.
  • emofarm Dec 07, 2007
    When I play a VHS tape, there is audio and no video. When play a VHS and record it to dvd at the same time [ dubbing ], I get audio and video.
  • allymarie Jan 01, 2008
    I am using HDMI cords to my television. The dvd's play find, but the a vhs tape only plays audio and no video . Instead, I get the blue dvd screen.
  • juliet1 Feb 19, 2008
    VHS has audio, but no video. The DVD player works fine.
  • macielou Jun 09, 2008
    I get audio but no video - what do I do?
  • wendyherd Jan 15, 2009
    I have a DMR-EZ47VEB which worked perfectly for last year but now when recording to vhs sound is perfect but no picture. Occassionally it will record perfectly but very frustrating.
  • bobaloo__525 Feb 07, 2009
    Same problem. Using ANY vhs tape, whether recorder on this unit, or pre-recorded, I get audio, but video. Can anyone help? DVD side works fine, with the exception of getting the RC1 error from time to time.
We cannot get the vcr portion to work only the dvd playerVHS has audio but no video - 4.gif works what are we doing wrong?
Have the same problem? Click Here
MikeNJ1964
VHS has audio but no video - guru_s.gif Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (chaVHS has audio but no video - 1.gif3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Posted on Jan 01, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 17 Answers
Pe will
This is actually an easy fix what you do is you take off lid the VCR cleaning everything with a Q-tip and a little alcohol all the gears accept the head with the head you use a cloth 4 eyeglass wear that's for anti reflective lenses and a little alcohol this will not scratch your head on the VCR
Then next you take.and use white grease and grease everything that has a track area being careful not to touch heads . You even do that tracks on the side of the VCR the ones that go in to the machine
Then towards the front of machine you will see two round gears lift those up slightly and check to see if white tape is in tracks if not push it slightly with a cuetip.
Then put machine back together as tape won't work with top of machine off
Plug in and hook.up IT should work now.
Good luck
Do this before you replace a ton if part
Posted on Oct 06, 2016
  • Diane Haggart Oct 06, 2016
    pe will
    Good luck
Clean the video head/ try to play w/ video head cleaner
Posted on Dec 28, 2007
What do you mean by/I get VHS video only when dubbing from VHS to DVD.????
Posted on Dec 07, 2007
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
I can play DVD's but not VHS tapes. I hav checked all connections and several tapes to no avail. Thank you ! Ol' Fred
Hey Ol' Fred...
One of my good friends is an ol Fred so I felt compelled to stop in and help!
I'm not sure of your setup, but if you've got a combo DVD/VHS unit, make sure that you have out puts to the TV for Both parts separately... You can designate by accessing the TV's onscreen menu and setting up a separate source for DVD and one for VHS. I've found on my projection TV that it's best to use the Coax cable connections for the VHS to TV.
Then once it's setup with separate hookups to the Tv, you should have audio and video for VHS...
k
Dec 18, 2009 | Televison & Video
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
Sylvania DVR90VF will not play home burned DVD-R disc
Search for DVD43 on the net. It's a free download. It works 99.99% of the time.
Jun 26, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Oct 24, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
1,323 people viewed this question
Top Televison & Video Experts
Electro Med Services...
