Question about IBM ThinkPad T23 2647 Notebook
Trouble finding the location of my hard drive
Lam having some problem finding the location of my hard drive in my thinkpa2647 notebook
    Sergeant:
  • 324 Answers
It should be located on the left side, and towards the front. It is removed by removing the security screw and sliding it out towards the left.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Nov 26, 2007
How to fix my netbook
The hard drive is located on the bottom LH or RH side of the laptop.
The BIOS setting will give you details of the hard drive that is installed.
Mar 12, 2012 | Dell Latitude 2100 (blcwwfp) PC Notebook
How to find hdd for toshiba satellite laptop 1715xcds
The physical hard drive is normally located on the bottom of the laptop. Normally when your turn the laptop over and let it sit on the lcd screen you will see an icon that has 3 circular discs that house the hard drive. Normally there are only 2 screws on the bottom case to remove the cover. Then you might have no screws or 2 - 4 screws that hold the hard drive in place. Remove them and just lift the hard drive out. Some drive will lift up, others you will have to slide backwards then lift up. There will be a piece of plastic on the drive for you to grab to lift it. If the drive is not on the bottom, then it will be located on the inside under the keyboard which means you will have to remove the keyboard to get to it.
Mar 10, 2012 | Toshiba Satellite 1715XCDS Notebook
My V30 laptop is telling me that it cannot find any hard disc drives, can you help please.
it means that you hard drive broken so it can't detected by the system
replace your hard drive it located in the back cover of your notebook.Open the screw and replace it, put your hard drive on the refrigerator for 1 night to check if it can use again, but if it can't you must replace with a new one. good luck
May 23, 2011 | Samsung V30 Notebook
PVC HID 1000 cards were getting stuck/bent in the Lamination module of our DTC550 printer. Talked to the tech department where we bought the printer/lamination module. They suggest because we are using...
Turning down the lam temp and dwell on the lam unit should have no effect on image color - they affect the processes only AFTER the printing of the card is complete. Make sure you were making adjustments to the LAMINATION settings, not the printing settings.
As to the noise, squeeks and groans emanating from the lam unit usually means mis-loaded lam film. Check the loading of the lam film in the printer and make sure it is not binding on the spools, and that the spools turn smoothly. Other than that, it could just be your printer showing signs of age. They have been out of production for more than 5 years, and do break down with age and usage.
Apr 28, 2017 | Fargo DTC550 Thermal Card Printer
Installing new oporating system, laptop can't find the hard drive
your hard drive might ne bad. most toshibas have a hard drive test utility use it and check the drive set drive to master if it has jumpers
Dec 05, 2008 | Toshiba Satellite A100-S2311TD Notebook
Hard drive trouble
in Windows right click on the disc drives icon in my compter and open the properties.. Click on the tools tab... Click on the check now button in the error checking section this will check the drive selected and optionally fix any errors it finds on the hard drive... after that assuming it went well and nothing drive-life threatening was found and could not be fixed youshould be able to complete the task you set out to do
Oct 19, 2008 | Toshiba Satellite L15-S104 Notebook
Remove hard drive from ecs g900 laptop
To access it it is on the bottom and you have to remove the screws
but you should BACK UP FIRST
Aug 28, 2008 | EliteGroup ECS G900 Notebook
How to upgrade my twinhead notebook hard disk?
I've never had the pleasure of working on one of these. What I do when trying to find the hard drive in a machine I'm not familiar with is put my ear down to the machine, start it, and listen for the hard drive to kick in. This let's me know where it is, then I look the machine over to figure out how to get to it systematically. On most laptops, there is a cover on the bottom or the side that hides the hard drive. If on the side, it's generally a caddy that is held by a screw on the bottom, and the hard drive slides out with it. On some models they put the hard drive under the keyboard or palm rest/touch pad. So, listen to find out the location of the drive, then look for a cover on the side or bottom in that area. If there's not a cover, then remove the keyboard and check if you can see it. I know this isn't the answer you were looking for, unfortunately there's no manuals on line, but I hope this helps, and get you started in the right direction.
Aug 09, 2008 | Twinhead SlimNote N12PI Notebook PC
Hard drive
ok your hard drive isnt recognized, it may not be connected. Try locating the hard drive. Sometimes it is accessible from a bay on the side or bottem, other times it is located under the keyboard, check that it is securely plugged in.
Jan 29, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
IBM ThinkPad T23 2647 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
