Computers & Internet Logo
Bill Smith Posted on Oct 15, 2018
Crosley composer CR247 it has a liteon lh52R1P483C drive i need a replacement
2 Related Answers
  • 6688 Answers
  • Posted on Jun 04, 2011
SOURCE: need a user manuel for a Crosley#CR247 where can I
If you have the Crosley Composer CR247 CD recorder and turntable, the manual is available from the product page from Crosley: http://www.crosleyradio.com/Product.aspx?pid=1791 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR247_Manual.pdf .
I hope this helps.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Nov 07, 2016
SOURCE: Where can i buy a remote or order one for crosley cr247
http://www.remotes.com/product-p/crosley%20cr247.htm
How and where do i order a remote for my crosley cr247
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
2helpful
2answers
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim [email protected]
Need a user manuel for a Crosley#CR247 where can I find one?
I hope this helps.
4helpful
2answers
Cd drawer wont open cr248 songwriter
I have the Crosley CR247 which is the same except for style. I had same problem.
The CD drawer stuck and would not open. It made sounds like it was trying. I could not find any information on a solution, but from what I had been reading on other CD Drawer problems, it sounded to me like there had to be a manual emergency release somewhere. Could not see one anywhere on the unit, so I took a butter knife and inserted in the crack just below the tray. I slide the knife from left to right and just very gently ppressed around with it. When I had it over to the far left hand side moving it over just about an inch and a half to two inches, I just slid the knife from side to side and it opened. Sorry, I am not a mechanic or do not know how to fix things, so this is the best that I can do to explain where the emergency release is located. My little rubber belt drive looked good, so that wasnt the problem. I just opened and closed my drawere about five or six times before I felt that it was safe to stick CD in. I don't use it much, maybe that was the problem. The trick is getting the darn door open first so that you can see if it is the belt drive or not. Good Luck to anyone with the same problem.
2answers
I need the manual for crolsey player recorder model cr247-pa
Download from Google Exemple type on google .. (download Crolsey player model CR247-PA manual & drivers Then take the one you need good luck
2helpful
Do i have to flash a new dvd rom drive if i replace it with an old brioken 1 on the xbox 360?
Not if you have the same model. Meaning if it's a Samsung, you replace it with a Samsung. Or a Liteon with a LiteOn.
All you have to do is take apart the drives and swap the circuit boards. They are on the bottom of the drive and it's not difficult.
If you need to buy a drive, I recommend http://parts.consolerepairguy.com They are about $30 there.
I repair them, so I'm sure about this.
1helpful
Crosley CR247 never used, sat for almost year, display :"OPEN"
seems you need to go to the spesific mode, fono, or radio mode.
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
Lost recording software kit
If you lost the software, you can try contacting LiteOn for a replacement, but you'll probably have to go to your local tech store and buy more software. I recommend Nero or Easy CD/DVD Creator, or get the opinion of someone that works there. Make sure you do NOT open it until you get home and check online that it has the features you need, as you will be unable to return it if you open it.
Grand Canyon Tech
Grand Canyon Tech
