Do you know where I can download a scanner driver for this multifunction printer?
Here's what you can try to get your scanner working:
SOURCE: Can't find printer driver for Epson T88iii printer
Thank You For Choosing FixYa!!!
If you Wish. I will take remote Control of your computer and I will try to Fix it.
Link will Only Work for 15 mins. So Click on the below link as soon as you get this message.
Click Here, It will Take you to a Page, where you can see download Button.
Click on the Download Button, Open and run it. It will be automatically Connect to me.
SOURCE: Samsung Printer/Fax/Scanner/Copier SF-5100P drivers free download
http://www.printcountry.com/drivers/SAMSUNG_SF_5100P_DRIVER_DOWNLOAD.htm
click the link directly.
thank you.
SOURCE: how to download samsung SCX 4x 16 series scanner
goto www.samsung.com and use the search box at the top right and type in the exact model, the x to substitute for numbers/letters isnt helpful so type the exact model in there and it should have a page to download the drivers
SOURCE: i want canon ir3300 multifunction printer drivers for windows xp
i want ir3300 cmputer drivers
SOURCE: HP Solution Center does not recognize the scanner
I had the same problem and solved it. I was using HP Solution Centre to run my HP Scanjet 5590 on Windows 7 Pro 64 bit without problems. Then I ran the scanner using Windows Fax and Scan, but didn't like it, so went back to HP Solution Centre - whereupon the scanner was not recognised.
After hours of reinstalling software etc etc, without success, I suddenly noticed four device icons on the left hand side of HP Solution Centre. These were labelled (when hovered over with the mouse) hp scanjet 5590, hp scanjet 5590 #2, hp scanjet 5590 #3, hp scanjet 5590 #4. Only the top icon was active, but when I clicked on any of the four it moved to the top.
Clicking on hp scanjet 5590 #2 gave me a working installation once more - problem solved. No doubt the multiple icons arose from my desperate attempts to try different USB ports.
