Download Kubota Tractor Manuals
Websites:
1. Heavy Equipment Service Manuals
2. https://heavy-equipmentmanual.com/
3. https://store.payloadz.com/results/376351-heavy-machine-manuals
Contact Email: [email protected]
SOURCE: How do I get the drive axle out of its transmission housing?
Yes ,it should just pop off.Have someone pull a little on it while you tap on the axle.There is an inside shaft that the outer shaft slides onto and there is a c-clip holding the two together. Sometimes the inner shaft pulls out with the outer axle if the clip doesnot release.If this happens you'll have to be carefull putting the inner shaft back in,because there is a washer at the end that may fall down and the axle willnot go back in.There is a pilot bearing at the end inside that the tip of the inner axle goes into and just before it is where the washer is.
SOURCE: left front popping. already relaced hub assembly. What next????
The top is a 216. The bottom one is a 248. Your option's list calss it something different so I don't know which it is. It sounds like you've got a problem with the u-joint. They're easy to check. If you see a lot of bright orange rust around them, they're bad. Also, put the truck in 4 wheel drive, make sure the front axle engages, and grab the front driveshaft and turn it back and forth sharply while watching the u-joint. If it's bad you'll see the axle side roate a little bit but not the wheel side.
SOURCE: axle roar
Could be any one of the bearings in the rear axle. Suggest taking it to a reputable transmission shop to get it diagnosed further.
SOURCE: removing a left front axle
there is a cir clip about 5ml in from the edge use a small flat blade screw driver to get under it .and needle nose pliers to hold the end whilst u run the screwdvr around in an arc to dislodge it
SOURCE: front drivers window dropped out of track
These are called window sashes. I took my car to strauss when this happened If you cannot fix it urself. It's 45 dollars to check out all the problems of the window and if you just need the clips they'll fix it for that 45 as well. If the window regulator is good then the clips will cost you about 10 to 15 bucks. If it isnt, the regulator runs about 100 bucks.
Fig. Fig. 9: Removing the ball joint to steering knuckle clamp bolt
Fig. Fig. 10: Remove the retaining bolt and remove the speedometer pinion from the transaxle assembly
Fig. Fig. 11: Separate the ball joint from the knuckle by prying downward against the knuckle and arm
Fig. Fig. 12: Separate the outer CV-joint splines from the knuckle hub by holding the CV-housing and pushing the knuckle out
Fig. Fig. 13: Support the assembly and pull outward on the inner CV-housing to free the assembly from the transaxle
Fig. Fig. 14: Separating the assembly from the transaxle
Fig. Fig. 15: Removing the assembly from the transaxle
Fig. Fig. 16: Removing the seal from the housing using a suitable prying tool
