Question about Acer AL1711 17" Flat Panel LCD Monitor
Monitor goes black
Have an lcd monitor when turn power on acer comes on screen then screen goes black-then when computer boots up-screen comes on & goes black constantly like losing signal-have bought new power cord & vga cable & tried changing resolution but still not working-had to go back to my old heavy monitor and that works fine-so video card is working ok-any suggestions other than monitor itself is malfunctioning
  • 116 Answers
Re: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
0 characters
3 Points
My ACER 22" monitor goes black after computer
What model Acer do you have? Email me at and I will try to help you get it going again.
Jul 03, 2012 | Computer Monitors
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
Monitor goes black
dry soldring problem in your monitor
Mar 31, 2009 | Acer AL1751WM (Silver) 17" LCD Monitor
Why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Feb 24, 2009 | Acer X193W LCD Monitor
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Acer AL1511 15" monitor Screen Menu Problem
What operating system do you use? If it is a windows OS press F8 while the system is booting to access the Boot Manager, choose to boot to last known good configuration and if this does not work retry but select safe mode and change the resolution back to the previous one.
Jan 19, 2008 | Acer AL1511 15" LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computer Monitor
hmmm chek the power board in the back chek resistors and ic's in ocilloscope good luck
Oct 12, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Acer AL1711 17" Flat Panel LCD Monitor Logo
1,618 people viewed this question
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
