Thermostat problem or problem with damper that controls airflow between fridge and freezer
Testimonial: "What is a "damper"? How can I tell whether the problem is the thermostat or the damper? The fridge-freezer is only 3 months old, so is it likely to be the the thermostat?"
Where air flows from fridge to freezer
Call warranty
If only 3 months old
If your damper is electronically controlled, it may be stuck open.
Thanks!
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad. When doors are opened, the fan stops. No cooling. When it closes, fan starts. Bulb is just an indicator of no power to unit...probably burned out contact in switch.
SOURCE: The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp ..
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
SOURCE: fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Testimonial: "Thanks, I have checked that, but the vent at the bottom of the fridge section is a rigid plastic grill, which doesn't, nor looks like it should move. "
