Question about Ricoh Caplio R5 Digital Camera
Ricoh Caplio R5 Digital camera
Hi! what memory card is compatible with my Ricoh Caplio R5 Digital Camera?
Re: Ricoh Caplio R5 Digital camera
A SD-card will suffice. I have a SanDisk SD Ultra II which is really nifty since it also has a built-in USB-interface.
Posted on Nov 21, 2008
Not many but a FUJIFILM 1 gb card will do the trick
Posted on Oct 20, 2008
0 characters
3 Points
Where can I obtain a driver for Caplio R5 Camera Windows 7
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 02, 2012 | Ricoh Caplio R5 Digital Camera
I borrowed a Caplio R5 camera, have taken some super pics, but couldn't download onto computer. So took the memory stick to Boots and their developer couldn't find the photos. Put the memory stick...
The Photo's are currently stored on the cameras internal memory, you'll need to transfer them to the card using the camera's menu options.
Failing that, plug the camera into your PC and switch on, a box should appear asking you which programme would you like to access the new device with.
Select the folder option, then click on and open any folders therein, one will be the camera memory the other the card memory.
Jul 04, 2011 | Ricoh Caplio R5 Digital Camera
The image taken by my Ricoh Caplio R5 has horizontal lines across it. This happened after I deleted the previous images ready to start afresh. I then bought a new SD card to see if that resolved the...
The fact that the lines started appearing when you deleted images from the Ricoh Caplio R5 is probably coincidental.
It sound as if the problem is a faulty image sensor (sometimes incorrectly called the CCD or CMOS sensor, depending on what type).
If it's under warranty, contact Ricoh and have them repair it.
Jan 13, 2011 | Ricoh Caplio R5 Digital Camera
Camera caplio r5 i cant take any more photos because it is coming up car is write protected
Remove the memory card and move the little switch to unprotect, try again.
Apr 24, 2010 | Ricoh Caplio R4 Digital Camera
Card is write protected.
To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this 59a6de4.jpg .
Nov 24, 2009 | Ricoh Caplio R5 Digital Camera
Broken LCD Screen
Send it in for service...they'll replace the screen.
Aug 28, 2009 | Ricoh Caplio R5 Digital Camera
My computer won't pick up my ricoh caplio r5 camera even though it's connected via the cable, i've tried changing comouter ports with the cable
First download the latest drivers, then turn on camera and program if you are using one, then lastly connect cable
Aug 01, 2009 | Ricoh Caplio R5 Digital Camera
1GB Memory Card
try another card - 1Gb is like $10-$15 these days.
Feb 24, 2009 | Ricoh Caplio R5 Digital Camera
Ricoh caplio R5 digital camera
Flash not working Reset the ISO setting to a higher number Invest in a good image editor or even download the free Picasa
Aug 02, 2007 | Ricoh Caplio R5 Digital Camera
Ricoh Caplio R5 Digital Camera Logo
128 people viewed this question
Top Ricoh Digital Cameras Experts
Are you a Ricoh Digital Camera Expert? Answer questions, earn points and help others
