Question about Durabrand Portable DVD
Car Power plug problem.
We have lost the tip to the power pug in cord and can see the end of the fuse coming out of the power cord. The power cord plug has listed 12 volts in and 12 volts out. I tried to replace it with a 12 volt tap by cutting the cable and attaching the cable to it. That did not work. I tried buying two of the Walmart 12 volt power adapters the first one worked for less than a minet the second one did not work at all. That did not work. Where can I get the end of the factory power plug? I think that would be the easiest solution to my problem.
Thank you!
Albert Timme
  • 303 Answers
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Posted on Jun 01, 2009
Does my Casio g-200 keyboard have a fuse ? If so what type and where is it ?
I'd go exchange the power supply for the correct one (check the voltage, polarity and mA rating that's marked next to the power input). It may be too late, though.
There will be a fuse on the internal power input board, as well as one in the power supply, but if the instrument is turning on and lighting up, it's not a blown fuse.
Jun 29, 2016 | Casio Wk-200 Wk200 76-key Digital Personal...
What amperage does a "Whistler 1610" Radar detector take? I am buying a cord at radioshack and i don't know what kind of power cord to get.
All Whistler radar detectors operate on 12 volts. Non factory power cords should have at least a 2 amp fuse and have the center tip of the plug positive.
May 05, 2014 | 1610
How to charge it
Does it come with a 12 volt charger with the small round end or a 120 volt receptor..if 12 volt most any 12 volt with that plug will work..the 120 any extension chord..other way are use a plug that has a cigar lighter plug in each end you can plug it while driving it will charge..or you can simply attach it to the battery like jumping it and let your car run for a few min or unti the full charge light comes on when the test Button is pushed....tip after using it to jump let it attached for a few min after the car starts that will replenish the power used to jump..Good luck
Feb 05, 2014 | ITec Portable Power Station wJumpstarter...
Malibu 8100-0300-01
Promoters should include useful information. Not just air-head fluff.
Copy following link for actual useful do-it-yourself information such as warranty, troubleshoot, operation tips, manuals.
Aug 21, 2012 | Hardware & Accessories
I have a Whitler Pro 58 that needs a new fuse on the tim that goes into my cars lighter compartment. 1. Do you carry replacement tips and if yes, how much do they cost? 2. Is my model a 12 volt...
If you have the tip and all the parts to the power plug and just need a fuse you can get a 2 amp fuse from any auto parts store. If your missing the tip of your power cord, contact Whistler at 800-531-0004 and they will take care of you.
Aug 10, 2011 | pro 58 Radar Detector
My whistler quit working. How do I fix it?
What Quit? Does it not power up? If so, have you checked the fuse that is in the plug end of the power cord? The tip unscrews to reveal a 2 amp glass fuse. Does the lighter socket power other 12 volt devices? If not, check the vehicle's fuse box. Did you press or turn the power switch? (sorry had to ask)
Mar 15, 2011 | Whistler Vehicle Parts & Accessories
Hello I have a problem with my detector and that is, that the device just went off completely and won't turn on now?
Did you check the fuse that is in the end of the power cord? Does your lighter socket power other 12 volt devices? If the fuse in the power cord is bad, replace it with a new 2 amp fuse. If your lighter socket doesn't power orther 12 volt devices then check the vehicle's fuse panel.
Dec 07, 2010 | DE-1730 Radar Detector
Need to work a RAdar detector: whistler 1430
Does the unit turn on when you plug it into the lighter socket? If not, does the lighter socket power other 12 volt devices? IF the lighter socket works and the radar detector doesn't there is a fuse in the plug end of the power cord. Unscrew the tip to expose the fuse. Replace it with a 2 amp fuse from any auto parts store and try it again.
Feb 27, 2010 | Whistler Vehicle Parts & Accessories
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
The end of my 12 volt power supply cord was lost.
You might be able to use the parts from an old cell phone adaptor. Have you tried that?
If not don't mess with any off brand adaptor. Get another one from Garmin at their website Garmin .com
Jan 22, 2009 | Garmin nuvi 260W GPS Receiver
Durabrand Portable DVD Logo
95 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
