SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
SOURCE: "cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
SOURCE: air conditioner problem with 2005 chevy 1500 silverado
I have the same problem exactly, if i turn off the ignition and then turn it back on it begins blowing cold air again. I would like to know what the problen is as it sounds like it is not unique to just my vehicle.
SOURCE: My Air conditioner stopped putting out cool air.
The unit is overheating and tripping the internal overload of the compressor. Clean outdoor coils.....check outdoor fan to see if it turns or is siezed......possible bad Start/Run Capacitor which is a very common failure on condensing units......possible bad fan motor need replaced! Unit compressor can be cooled with a water hose to get it to reset the internal biometalic high limit switch that is located in the hermetically sealed compressor!
