SOURCE: Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
SOURCE: Huge temperature variation in Chateau by Moen shower only faucet
You bet....Pressure at the building varys with large use...8-10am or 4-6 pm....What floor you on...Higher the more pressure you need...maybe a pump...or plugged press.balance system....Not a novice handyman job...
SOURCE: GMC 2001 Yukon XL heater goes to full hot, no control
WellI don't know a whole lot about cars but my 2001 Yukon was doing this exact thing and I took it to the shop and it was the accuator under the seat! It was fairly cheap and now it's working perfect, hope this helps..... oh it was $90.
SOURCE: my temperature gauge on my bike goes straight to
THE TEMP GAUGE WORKS ON A LIVE FEED, TO THE GAUGE, WHEN THE COOLING SYSTEM GETS HOT THE GAUGE RECIEVES A SIGNAL FROM THE TEMP SWITCH WHICH IS ON THE THERMOSTAT HOUSING ON THIS MACHINE, ON THE RH SIDE OF THE BIKE UNDER THE INFILL BELOW THE RH HANDLEBAR, THE MOST OBVIOUSE REASON FOR THIS FAULT IS THAT THE WIRE HAS COME OF THE UNIT AND IS TOUCHING THE THERMOSTAT HOUSING, THUS MAKING AN EARTH, OR EVEN IT MAY HAVE BECOME HOT BURNING THE WIRE INSULATION AND IS JUST EARTHING OUT, WITH THE KEY TURNED ON REMOVE THE WIRE FROM THE TEMP SWITCH AND THE GAUGE SHOULD THEN DROP BACK DOWN, IF WHEN YOU REMOVE THIS WIRE THE GAUGE STAYS UNAFECTED THE PROBLEM IS WITH THE SAME WIRE BUT HIGHER UP THE LOOM, IF ALL ELSS FAILS YOU COULD REPLACE THE WIRE EXTERNALY LEAVING THE OLD WIRE DISCONECTED TO SEE IF IT WORKS THIS WILL ELIMENATE THE GAUGE BEING FAULTY, HOPE I HAVENT GONE ON TO MUCH, SIMPLE CHECK
