SOURCE: how do i take the heater core out of my 81 f150
Disconnect battery ground cable.
Disconnect cable from temperature blend door and the mounting bracket from top of heater assembly.
Disconnect blower motor and resistor electrical connectors.
Disconnect and plug hoses from heater core.
Working under instrument panel, remove 2 nuts on 1980---81 models, or 3 nuts on 1982---87 models, attaching left side of heater assembly and right side of plenum to dash.
On 1980---81 models, remove screw attaching top center of heater assembly to dash. On all models, remove 2 screws attaching right side of heater assembly to dash, then lift heater assembly out of vehicle.
Remove heater housing plate attaching screws, nut and bolt and the plate. On 1980---82 models, remove 3 heater core frame attaching screws and the frame. On all models, slide heater core and seal out of heater assembly.
Reverse procedure to install. Good Luck and hope this helps
SOURCE: heater/air cond blower only works on high. any
It is the Blower Motor Resistor located behind the Glove Box on the dash. Remove the Glove box to access. It is mounted against the fire wall. This is a common problem. My 2002 did the same exact thing.
1. Disconnect the negative side of Battery.
2. Disconnected the Electrical Connection to the Resistor.
3. Remove the bolts/screws. I believe they have 8mm heads, there should be 2 of them.
4. Replace with new one.
5. Reconnect the negative side last.
6. Test System before putting the glove box back in!
7. Enjoy the CONTROLLED HEAT!!
SOURCE: home air cond carrier A135H auto light flashes
Sorry don't have a solution for your problem, but I've got one that you may be able to help me with My Remote control, for which I have no user manual, seems to be locked and the buttons won't do anything. I have noticed a key symbol in the bottom right corner and cas only assume it is locked. Anyone know how I can unlock it? Cheers.
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
SOURCE: My heater in my XJ8 is not blowing any heat only air cond,
YOU MUST HAVE THE TEMPT BLEND DOOR TESTED BY THE DEALER,AND OR THE MATRIX DOORS HAVE SYUCK.
