Question about Frigidaire Washing Machines
I have a Frigidaire Affinity top load washer that is displaying "F8" and won't do anything. I understand that a control board needs replaced. Is this the one with all the buttons and knob or the black box behind the front cover?
SOURCE:
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
ngfam1
  • 639 Answers
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 25, 2008
  • 99 Answers
SOURCE: Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Posted on Feb 06, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
I have a top loading frigidaire affinity washer with what seems To be computer problems. How do I reset it?
Hey Kevin, I understand that you are having some problems with your Frigidaire Top Load Washer. Before considering contacting a service provider, I would recommend resetting the washer by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 10, 2015 | Frigidaire Washing Machines
I have a top load frigidaire affinity washer. Lately it seems to shut off mid cycle or sometimes run through the wash cycle while skipping some steps. Is there a way to reset the computer?
Hey, I understand that you are having some problems with your Frigidaire Top Load Washer. From what you have described it sounds like there could be something going on with the control board. Before contacting a service provider, I would recommend resetting the washer by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Why is it displaying f8 and won't start?
F8 is a malfunction of the control board. you have to call a repairman to let him replace or fix issue. Good luck.
Jul 30, 2015 | Frigidaire FAHE4044MW Affinity High...
My affinity front load washing machine will not start, there are no lights - nothing. The stackable dryer on top does start. Is there some kind of re start button for the washing machine
To Stranded,
Here is a link that will put you directly to free support and a manual to guide through the trouble shooting function. sparke needs help with Frigidaire Washer on ManualsOnline com . If you are familiar with a meter to troubleshoot and identify voltages. Start there. If the display is functional. Here is another forum you can tap for resources to compare. Basics first. How to enter diagnostic mode on Frigidaire ATF7000 washer Appliance... .
And you will need to take it apart.. here is the link for that solution.
Frigidaire Affinity Washer Disassembly
Say how you made out and if this approach helped please?
Fare. Well.
Sep 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
My affinity front load washer will not complete any cycle and the display screen goes blank.. what could be the problem
Hey friend, I appreciate your post!
From my understanding your Frigidaire washer, LTF7000ES0, will not complete a cycle and the display will also go blank. It sounds like it could possibly be a problem with your control board, drawer, or lock switch. Since it could be any one of these issues I would recommend having a professional come out to your home and repair your washer. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
When the motor is bad can it cause the Motor Control Board to go bad also?
Good Morning Friend,
I understand that you want to know if the motor is bad in your Frigidaire Affinity washer, model# ATF7000E, can it cause the motor control board to go bad as well. Just because the motor is bad, does not mean that the motor control board is bad. It depends on what is going on with your appliance. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine exactly what is going on. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
Code e ae frigidaire affinity
If you had a real heavy load in the machine, before replacing anything, remove the bottom access panel (two screws) and check motor control board and see if the plugs are fully seated(top will be up slightly if they are pulled off).
Feb 15, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidare affinity error code E23
Hello, welcome to FixYa.
I understand you have a Frigidaire Affinity ATF6000 series washer with an error code E23, correct ?
If that is indeed the error code you receive in the display it is potentially bad news unfortunately, as that indicates either loose wire (fingers crossed) or a failed drain pump relay on the control board. This is how it is described in the Frigidaire service tech manual.
Further to this, if it is not a loose wire at the pump or on the control, the only remedy is to replace the control board, unless you are proficient at electronic repairs (including soldering techniques) and can purchase an exact relay and replace just the relay...though that doesn't guarantee the control hasn't suffered collateral damage in the process.
A new control is part #134523106...
it is available at several on-line parts vendors such as "repairclinic.com" or "searspartsdirect.com" to name a couple as these links will provide.
http://www.repairclinic.com/PartDetail/Main-Control-Board/134523106/1191145
http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Washer-Parts/134523106/0026/417/Model-ATF6000ES1/1428/0153200?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=R0604038&diagramPageId=00001&productTypeId=0153200&searchModelNumber=ATF6000ES1&subCompDesc=Control%20panel&brandDesc=FRIGIDAIRE&modelDesc=WASHER&blt=11
Hope this answers your question and helps you move forward. Let me know how you make out or if anything isn't clear. Good luck and thank you for choosing FixYa today.
Regards,
Macmarkus :)
Oct 29, 2011 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My frigidaire affinity wont start
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
