SOURCE: Singer Sewing machine
I found the same numbers on my Singer, but learned that the 13608M is not the serial number. I finally found it on the bottom of the machine. It typically begins with either a single or double letter. You can find the Serial No. and Year of Issue at http://www.singerco.com/support/serial_numbers.html. You can also order a replacement manual. Another helpful site might be http://www.ismacs.net/Singer/singerdates.html.
Good luck.
SOURCE: singer simple comes with limited feet have been unable to find
janome machine feet should fit
SOURCE: I have a singer 3343c
the presser foot only holds the fabric against the feed dogs in the needle plate area
check the feed dogs to see if there in the up position
if not there should be a nob in the feed dog area to move them up & down
on some models when you remove the extension table the nob is at the back
SOURCE: wiring a foot control pedal for Singer
I have a singer advance 7422 and the outlet for the foot controller is kind of broken. A few days ago a little round black thing fell out of the outlet and now when i try to connect the foot controller it is very loose and the machine doesn't run. what should i do?
