Question about Jabra Radio Communications
My jabra classic stopped letting me hear my music. is there a setting i to adjust on my new iphone 6plus
SOURCE:
SOURCE: JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Posted on Jul 22, 2008
supernova278
  • 1932 Answers
SOURCE: I purchased a new Iphone and my Jabra will not
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Posted on Nov 12, 2010
EdNelson
  • 149 Answers
SOURCE: Cannot get my new Iphone 4 to pair with my Jabra
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 05, 2011
  • 13 Answers
SOURCE: How do i turn the ringer and microphone on in my iphone 6plus?
Check settings > General > use side switch to.. And make sure mute is not selected or toggle the side switch. Also check that you have set permissions on in your privacy settings on the YouTube app
Posted on Dec 28, 2014
desbloqueoce
  • 10 Answers
SOURCE: How do I turn phone ringer strobe light on in iPhone 6Plus
Just enable it here:
Inside your iPhone:
1- Go to Settings
2- Go to General
3- Go to Accessibility
4- In the section Hearing aid, Just turn on the option ALERT WITH LED LIGHT
Posted on Mar 02, 2018
  1. Launch the Settings app on your iPhone.
  2. Tap on General.
  3. Inside the General menu, tap on Accessibility.
  4. Scroll down a ways and under the Hearing section, turn the option for LED Flash for Alerts to On.
Jan 28, 2015 | Apple iPhone Smartphone
I can hear jingle bells in the background. You turn up volume with the the two larger buttons on the left hand side. Upper for louder and lower for lowering right down to mute. You need to be in the particular application when you adjust volume. In normal switched on and open mode, altering those buttons adjusts the ringer volume. Above those two buttons is the phones silent button. When you push it towards the back of the phone it turns off the ringer. When you are making calls, there is a mute button on the display. Also remember that the microphone is in the bottom edge of the phone next to the headphone socket. Don't cover it when you are making videos. Enjoy your new 6 Plus, they are amazing. I have the standard 6. It you have any other questions just ask.
Dec 27, 2014 | iPhone Apps
How do I "pair" the Jabara Journey with a I Phone 5C?
most pairing when asked by the device requires a 00000 passcode
but you need to set the jabra and the iphone up for pairing
here is a link for jabra the iphone should see it when the jabra is set to set up mode..
http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
Oct 11, 2013 | Jabra Cruiser InCar Speakerphone Black
Hi I have an iPhone 4 and jabra bt3030 worked perfect on my iPhone but in my iPhone I tap forget this device and the device was gone! now I can't find it again! what should I do?
    • 1. Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. It is the button that has an image of a telephone on it.
    • 2. Click on the "Settings" icon from the main screen of your iPhone.
    • 3. Click on "General" in your iPhone's "Settings" menu.
    • 4. Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
    • 5. Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
    • 6. Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
    • 7. Click on OK on your iPhone
Sep 13, 2011 | Jabra BT3030 Wireless Headset
My i phone 4 is not detecting jabra bluetooth device first it used to tetect but i purchased ne blutooth device while scanning for that device i found the old one i.e jabra so i clicked the option forget...
Does you new blue tooth device appear on other device or not. Reset you iphone setting and then again try to detect your new bluetooth device. Also check your bluetooth setting on your iphone to. Here is how to fix computer does not detect iphone or ipod
http://ipodtips-tricks.blogspot.in/2016/04/ipod-touch-does-not-detected-by-computer.html
Dec 26, 2017 | Apple iPhone 4 Black Smartphone
I paired my jabra bt 2015 with my mobile N91 NOKIA then i bought a new mobile nokia 5530 xpress music i can't pair it with the new mobile why ??? please help me
Go to Jabra site to confirm compatibility:
http://www.jabra.com/sites/mobile/ap-en/products/pages/jabrabt2015.aspx?submit=y
It says that they are compatible.
Dec 21, 2010 | Jabra Bluetooth Headset with Adjustable...
Jabra BT2035 needs a code to connect to my iphone
my jabra BT2035 needs passcode to connect to my Nokia X6
Jun 24, 2010 | Jabra Bluetooth Headset with Adjustable...
I can't listen music through my bluetooth headset with iPhone
My Jabra Halo works to play iPhone's iPod music as well as phone calls. So does Jabra Arrow, I'm told. The bluetooth must have A2DP.
Aug 20, 2009 | Apple iPhone 3GS Black (16 GB)
Jun 18, 2008 | Jabra BT250 Consumer Headset
Radio Communications Logo
57 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
